Since I didn't want to misuse the rig-thread I decided to make a new one for technical questions about PCs/parts where everyone can ask questions and everyone can answer.
The reason why I even consider a NAS drive is that my ext. LaCie HDD was in use for the last 2 1/2 years nearly everyday for 2-12 hours with constant video/music playback. Since NAS drives are built to endure this kind of usage I thought those would fit my needs.
I don't really care if I buy a WD or Seagate. My last main drive where I had the OS and ALL my programs, documents,... on was a Seagate and I never had any problems (well, the ones in the living room-PC died, had to replace them with my ext. Seagate via eSATA; types are ES.2(int) and Barracuda 7200.11(ext)).
I wouldn't mind buying a normal HDD (WD Blue, Seagate Barracuda) if it can handle the workload but as I calculated it should at least!!! be able to handle about 100TB/y. Like I said, the HDD will be in use for media playback (like in a NAS).
But credit where credit is due: since my ext. LaCie (have to look up what HDD is actually in the case) isn't a NAS drive it handled the workload pretty good for 2 1/2 years and it still works (copying the most important data to my int. WD Blue). Only downside is that when I run Speccy or it is idle for a longer time, it suddenly doesn't get recognized by the PC anymore (altough when I disconnect the USB cable or turn the LaCie off I get the "disconnect sound" from Windows). It also makes a "crunchy grinding" noise when writing (don't know what it means but I already backed up all files on it).
So, the question still remains: what HDD for media playback? Is a NAS drive worth it or does a WD Blue/Seagate Barracuda the job equally good?
I want to get a new one as soon as possible since the free space on my other drives is getting scarce :-/
