Samsung ATIV S and my Work Exchange...not working
Cordanim
15
Hi all,
Long time BlackBerry user here and made the switch to Windows Phone 8 - went with the Samsung due to the larger screen and expandable memory :)
So my IT guys get the phone in and then tell me that they can't get it to sync with EAS which they're baffled at, since they just set up some Nokia 920's for a couple other execs with no issues...anyone else with a Samsung ATIV S and trying to get Exchange set up having this issue?
They tried the manual certificate install and still nothing...the error I get now is that the credentials for logging in are not correct - yet they are the same ones I use for OWA from my laptop, etc. For now, I just surf to OWA on the phone but that's very clunky and I'd like to get this fixed up before traveling next week :(
Thanks,
Kev
1point8T
3
I'm using my ATIV S with my work Exchange without any issues. The procedure to setup the Exchange account should be exactly the same as the Lumia 920 as it is not device specific. Ensure some of the basics like your domain is correct, your username is correctly entered and obviously your password. If your company requires a secure connection(which I assume every company should) make sure that is checked in the setup.
Cordanim
15
That's what you'd think but they've set it up the same as the guys using the Nokias and something doesn't allow it to work :(
We do require SSL to be enabled and it is...was just wondering if anyone else was having trouble...
Thanks 1point8t
Kev
Petlaw99
5
I had no issue at all with a connection to my work Exchange. Set it up exactly as per my previous Lumia 920 and it worked out of the box, very simple. The only phones I have ever had Exchange issue with were Android.
JoshRos
