Hi,
has anyone else had any issues with corrupt files on their ATIV-S when using the camera?
I have a 64GB SanDisk Class 10 (HC 1) sd-card and I have had a situation twice where just as I am taking a photo something else happens on the phone (a text message arrives, or an alarm pops up) - this seems to interrupt the photo save and the camera stops working. After a reboot the camera app will start, but then just shuts if you try to take a picture.
to fix the issue I put the sd-card into my (Win 7) laptop and it pops up the message about wanting to scan and fix errors. I let it do that, it says "no errors" found. If I then look at the photo (on the pc) its only partly written (like a third of the picture is visible).
The first time it happened, I deleted the half saved file from the card whilst it was in my laptop. second time I thought I'd see if the camera worked after the fix, but without deleting the file. It works fine in the phone and I can see the half saved file too.
The card is brand new and was formatted by my Ativ-S.
My phone is running the Portico update (was delivered with it)
