It's just for games like Alphajax and so, that need other "online" phone-users. Ya, the mini-diary.... 0-0 all the memories that were SUPPOsed to be recorded :unhappysweat: it's not always, it's just like 1) i learned that you can't just press the plus sign, and press the tick after you've finished your entry. If you do that,then go back via the windows button, then it automatically deletes it, because you didn't press the 3 dots and THEN press save, and after a lot of painful hardships and losses....(my entries!
) i learned that you also have to turn the diary page before you press the windows button,otherwise even though you pressed save, and you pressed the tick several times(which i assumed was mini-save), ALL, and i mean ALL your work is gone, like- literally! :grincry:
The copy-paste thing... ya, i mean, if you have like a word document, you put it in your phone, it doesn't even recall it, you don't see it as an icon or anything anywhere... 0-0 Apparantly, you have to downlolad a hfs server, and transfer your files via that :wink: but the prob is....
YES I DID DOWNLOAD IT and....
and....
:crying:
It was for a test i was supposed to write today, so i wanted to study from my cellphone during the day, before it.
The icons did turn up at home, but when i went somewhere else(w/no internet) it got destroyed!! or something.... lol i'm being dramatic, but tough day, huh? :winktongue: I came home and plugged my cellphone in again, then i checked- it was there. I take it out of my computer, then check- gone! And THEN i learned you have to press a "save" button after opening each single document on your cellphone. But my "save" button is in grey, (others in white) like you can't press it. There's also "save as" but that's just dropbox, and it's probable that wherever i head out, there is no internet :amaze: So....
