Watch UFC 245 Exclusively on ESPN+
Catch Every Moment of UFC 245 Experience UFC PPV events like never before with ESPN+ and save over 25%!
Expand Minimize
07-27-2013 10:27 AM
26 12
tools
  1. trxmec's Avatar
    I am quite satisfied.
    Pros:
    - it is impossibly thin.
    - it has a great battery life and the battery is removable.
    - it is light
    - design, there is much talk about Ativ design. Many say that is classic and lacks of personality. In my opinion it's very nice, it is a premium and intriguing look. I did not realize till I had it in my hands that the Gorilla glass is a bit curved at the disply edges, making the phone nice to handle. The rear is nice as well... with that aluminium-like cover which looks like metal.
    - it has an impressive 4.8 display. Even if here, coming from an HTC Titan with 800x480 and around 200DPI resolution, I was expecting a bit more from 1280x720 Super Amoled with 326DPI technology. It has extraordinary deep blacks but I was expecting it to be brighter at max settings and I was a bit puzzled to see quite severe colors/shames changes by tilting the phone of few degrees (from white/green background to rose and the like). Maybe it's just me not used to Super Amoled.
    - it is responsive. I did not experience any lag, in no circumstances
    - good camera. Not at Nokia's level but it does what need to do. Still need to try it sunny landscapes
    - memory. Built in memory (16Gb) is enough and the capability to expand it with a SD (additional max 64Gb) is a pro
    - home button. I like to have a physical button.
    - call quality. Loud and good conversations. External speaker works fine.
    Cons:
    - poor customization. I don't know if it is a fault of Samsung or it is dictated by limits of WP but I was expecting Samsung at least to develop more as integration of the pure OS (eg camera options)
    - software support. Maybe it is just my hardware, but the manufacturer SW (Kies) does not connect and MS app does not work as expected (does not record settings, does not work properly for sync etc)
    - no LTE support
    - accessories. The market is offering more and more accessories but I did not find a bumper or the perfect case yet. Maybe in the future
    - many have the impression/fear that Samsung does not really believe in WP expansion and this phone will no longer benefit of updates. I hope Samsung will clear those doubts showing dedication to this model.
    Glad to see your comments
    Mankku and xandros9 like this.
    03-17-2013 11:03 AM
  2. Mankku's Avatar
    Had the Ativ S for about 2 months, ever so pleased with it! :) Good review! I agree with you on most points regarding the phone.
    In my opinion the call quality isnt that great, but it could depend on my carrier here in Finland. Audio quality is very detailed, Ive noticed a lot of new sounds when listening to music through good headphones, and the output is strong. Recently a Flac player showed up in the market (still only possible to download from a Skydrive-account, not store on the card), and the possibilty to listen to high quality recorded music just got even better, even 96 kHz is supported :)
    Yeah, lets hope Samsung will provide updates / support for this phone in the near future; a lot of people are pessimistic, but Samsung is releasing th Ativ S to new markets now, so its perhaps too early to tell if Samsung is really ditching WP8.
    03-17-2013 01:12 PM
  3. trxmec's Avatar
    Thanks Mankku, I think the phone is a bit underestimated and I am glad to hear other positive opinions about this device
    03-17-2013 02:57 PM
  4. Coolknight1968's Avatar
    You forgot to mention that the phone awakes from sleep when you push the physical home button :-) I love that feature!
    03-17-2013 05:24 PM
  5. trxmec's Avatar
    Yeah, do you mean that you push home when it is locked? I think this is nice and I love the physical home as well. I mentioned that! :-)
    03-17-2013 07:34 PM
  6. pedenske's Avatar
    Only had mine for a couple days now but that review is pretty much spot on for me, except for the lack of LTE. SGH-T899M Canada Version :D
    03-19-2013 03:07 AM
  7. WasteSomeTime's Avatar
    Don't all windows phones awake from pressing the home button?
    Sent from my SGH-i677 using Board Express
    03-19-2013 03:50 AM
  8. Smg-Uk's Avatar
    Nope the Lumia's & HTC's i've owned all only wake from pressing the power button and not the home button but then the Ativ is quite unique in having a physical button.
    03-19-2013 09:05 AM
  9. anon5658834's Avatar
    I think the camera is excellent and better than some Nokia's
    07-14-2013 07:54 PM
  10. phonohead's Avatar
    I just put my thoughts on the line in someone else's "personal review" thread.
    http://forums.windowscentral.com/sam...s/215458-3.htm
    07-14-2013 08:22 PM
  11. failed1234's Avatar
    Sounds awesome. Deciding between this and a 920. What should I get?
    07-15-2013 10:59 AM
  12. phonohead's Avatar
    You ask a Samsung owner, you ask a Lumia owner, you're most likely ending up with a pretty obvious answer from either two. You should read the "reviews", and perhaps make up your own mind about it; consider what you need and what pleases you the most about the devices.
    07-16-2013 02:41 AM
  13. z33dev33l's Avatar
    I'd say go for the one with software support... They're similar in quality but the software support makes a near infinite difference.
    07-16-2013 02:48 AM
  14. Exotic Hadron's Avatar
    I would add a single major con I noticed in Samsung ATIV S after 2 month of using the device. The camera. It is not supported by the majority of camera apps (lenses) over at WindowsPhone.com.
    • Clever Camera
      Doesn't work at all. It starts successfully but once a shot is made and shutter is pressed, nothing happens. No shot is made.
    • Camera360
      Exposure works quite strange.
    • ProShot
      Doesn't work at all. Crashes on manual focus, fails to start after you attempt to make a timeline/burst shot.
    I am quite disappointed with that. I'd love to use the camera in full, but I can't. The only lenses that work fine are built-in camera and BLINK. Both by Microsoft. Other cameras crash every now and then. That alone, the phone is fantastic.
    07-16-2013 12:34 PM
  15. Exotic Hadron's Avatar
    I am a Samsung ATIV S owner, but provided that Nokia issued Lumia 1020 that sports a SuperAMOLED screen and a 41 Mpx camera, I'd recommend going for Nokia.
    Yet one plus you'd get from buying Nokia is their Lumia storage check beta that allows to mitigate the notorious issue with Other storage where the phone gets bloated with service/temporary data consuming all available space on phone's memory.
    More here:
    07-16-2013 12:42 PM
  16. failed1234's Avatar
    More here:
    The 1020 is a wee bit expensive, even on contract.
    I also have large hands, which is why I'm considering the Ativ S.
    07-16-2013 04:46 PM
  17. Coolknight1968's Avatar
    The Ativ S is a good value and has a good battery. Reception is good but not as good as on a HTC OneX+ or HTC One (signal reception). I love mine and will keep it a while as it works near perfect on Orange. Camera is surprisingly good when there is sunshine and no where near the Lumia 920 or HTC One in low light conditions. I love the 4.8 inch Amoled display.
    07-17-2013 01:09 AM
  18. Villain's Avatar
    no LTE?
    07-25-2013 01:57 AM
  19. phonohead's Avatar
    no LTE?
    No. But, between LTE and HSPA+ there's not much of a difference.
    07-25-2013 07:32 AM
  20. Matthew Becker1's Avatar
    no LTE?
    The Canadian version (SGH-T899) is LTE-enabled. The i8750 version is not.
    07-25-2013 11:43 AM
  21. Arier's Avatar
    Im quite surprised about the camera quality, its ineed better than some newer nokias. The daylight shots are amazing, shame theres no pic thread in here.
    07-26-2013 04:23 PM
  22. phonohead's Avatar
    You're wrong, sir. There is, it just needs more attention and publishing!
    http://forums.windowscentral.com/sam...ser-media.html
    07-26-2013 09:09 PM
  23. Apostolos Tsimogiannis's Avatar
    Been using an Ativ S for about a month coming from iphone 4S. Overall a great device. Most points of OP are right.
    Sound quality is a big improvement over the iphone and the screen rocks. Love the 4.8" screen and the responsiveness although sizewise it is for me at the limit for a phone.
    Also the camera is better than i expected.
    I do not like the back though. I never use cases and the plastic scratches. Back cover easily, sides less so. The phone will look brilliant and fresh up front but the back will look used and "dirty" very soon.
    Price tag for the spec of the device is amazing.
    Love wp looks and interface and want to see it develop.
    07-27-2013 02:19 AM
  24. phonohead's Avatar
    May I ask how much you paid, and if you bought it without a contract? I paid €190 for it, off contract. Sadly it was for my mom.
    07-27-2013 08:03 AM
  25. murrayalex's Avatar
    Picked one up for about 220 in UK off Amazon, for the specs that is a remarkable bargain. I did have a Lumia 925 but sent it back for build quality issues and in many respects the Ativ S is a better phone in most departments apart from the camera's overall performance under different lighting conditions. Very pleased with it.
    Chemilinski likes this.
    07-27-2013 08:58 AM
26 12
  1. Excuse Me..Uhh Where is My Ativ S?
    By andrelamont in forum Upcoming & Rumored Phones
    Last Post: 11-07-2012, 03:06 AM
  2. How do I get my apps back after a reset?
    By sting7k in forum Windows Phone 7
    Last Post: 04-19-2012, 05:42 PM
  3. Replies: 8
    Last Post: 03-24-2012, 09:46 PM
  4. Had my Titan for a week now, status
    By kevm14 in forum HTC TITAN
    Last Post: 12-02-2011, 02:56 PM
  5. My WP7 review
    By archer75 in forum Windows Phone 7
    Last Post: 10-15-2011, 05:38 AM
