I've this phone from thursday. I knew that this has a great battery life, but for me seems to be different.
The screen is in italian, but is quite understandable. 8 Hours 59 mins remaining, and it drain 10% hours. I took the screen about 1h after last charge.
I only have turned on WiFi and Net Access 3G.
I also removed Whatsapp, Kik, Skype, Viber and Chat On, but as you can see it doesn't change the battery drain problem. But I have also to say that the app updates stats not so often.
Things are better only if I turn on the Airplane mode. In this case, it lower to 4% the drain.
p.s. Is there a way to charge the phone with the power turned off? It turn on every time I plug the charger. Annoying.
