diagnosis tool - battery
p111
32
hi,
has someone run the diagnosis tool on ativ s yet (*#634#)?
If you run the tool, that is installed after you dialed as above, and you press *#2*#, you will see information about battery wich contains three pages. on page 3/3 I find on top "MAX 17048 FG".
Can anyone check this on his/her ativ s and post the value? Is this the capacity? doesn?t it have 2300? Is the 17048 another value, or does my ativ s have the "batterybug" of the older lumias?
thanks in advance!
mase123987
3,118
Try taking screen shots and posting them, so it is easier for everyone to understand. (Power button + Windows Key at the same time)
powerupgo
