So I was using GoodDayToDie's webserver native access (access system files from web server) and I found registry entries for MSM8960 by both qualcomm and Samsung. MSM8960 is an LTE SoC. Samsung ATIV S actually has LTE!! It is just disabled!
are you completely sure about that? It might be just there, like the FM radio entry, you can enable it but it won't work.. are there any other SoC's mentioned? If not, that'd be really awesome
It's common knowledge the Ativ has the MSM8960, it was in the spec sheet it was announced with, it won't magically grow an amplifier and requisite antennas to use LTE if you somehow manage to enable the baseband, which I can guarantee will take more than a few file changes and registry tweaks.So I was using GoodDayToDie's webserver native access (access system files from web server) and I found registry entries for MSM8960 by both qualcomm and Samsung. MSM8960 is an LTE SoC. Samsung ATIV S actually has LTE!! It is just disabled!
it all depends which model you have. the SGH-T899M has had it since day one. for some reason, gsmarena ATIV S spec page, they don't mention LTE at all, which is not good since I'm sure LTE is a selling point. gsmarena should correct that.
Sorry, but this proves nothing. If LTE was available for the i8750, then why would Samsung release it as disabled? That makes no sense.
If you not see with your own eyes you never sure 100% about that. Some specs mentioned the 8260A and anothers MSM8960. For example: WP's official UK site check the processor. Do you think on the official WP site they are lames and wrote false information about the phones?
