1. Ivan S's Avatar
    Hi, I forgot to change for Ativ S before starting using it.
    Is it OK for my battery ? (I also noticed that battery was charged 300 (!) days ago before I turned on the device)
    What is the usual life time?
    And the next question.. is there any way to enable strong passwords on the lock screen?
    09-15-2013 04:50 AM
  2. WanderingTraveler's Avatar
    Hmm. I'd recommend that you go through at least one charge cycle to make sure the battery is up to snuff.
    If you define life time as how long the phone lasts on one charge, it should be around a day with moderate usage (*my definition used), with enough juice to last a night.
    As for strong passwords, if you define these as alphanumeric combinations, nope.
    09-15-2013 06:25 AM
  1. Replies: 15
    Last Post: 06-27-2014, 11:16 PM
  2. Replies: 3
    Last Post: 12-17-2013, 10:43 AM
  3. Replies: 56
    Last Post: 09-24-2013, 03:40 PM
  4. Microsoft need to have more updates Android apps can penetrate os systems.
    By eugie in forum New to the Forums? Introduce Yourself Here!
    Last Post: 09-16-2013, 07:44 PM
  5. Contacts - nicknames and moving contacts
    By hitchhiker90 in forum Nokia Lumia 822
    Last Post: 09-15-2013, 02:45 PM
