1. Pavlov Effect's Avatar
    i save the apns settings and i come back and the proxy&proxy Pot &mmsc adress doesnt show
    is there any solution? i cant send mms because it get deleted every time..
    04-20-2014 03:29 PM
  2. neo158's Avatar
    Are you using the APN option in settings or Mobile+SIM?
    04-21-2014 05:51 PM
  3. Pavlov Effect's Avatar
    are you using the apn option in settings or mobile+sim?
    settings i dont have option for apn in the mobile+sim
    04-22-2014 05:42 AM
  4. neo158's Avatar
    Yes you do, at the bottom there's SIM Settings and selecting that allows you to name the SIM and enter internet and MMS APN settings.
    04-22-2014 02:40 PM
  5. Pavlov Effect's Avatar
    all i can do is change the same of the sim :\
    i dont have an option for apns
    04-23-2014 06:22 PM
  6. neo158's Avatar
    Can you post a screenshot, you should have two buttons one labelled "edit internet APN" and one labelled "edit MMS APN" at the bottom of the screen.
    04-23-2014 06:52 PM
  7. mary beth hale's Avatar
    darn, wish I could see what you see when you go to settings>cellular+SIM>SIM settings. neo's description/instruction is spot on. any chance you could post a screen shot of what you see in SIM settings? this is what I see
    neo158 likes this.
    04-23-2014 07:01 PM
  8. JWSHale's Avatar
    Probably like mine - I don't have the manual settings either:
    04-24-2014 08:12 AM
  9. neo158's Avatar
    Click image for larger version.
    Have you or the OP tried a factory reset?
    mary beth hale likes this.
    04-24-2014 12:01 PM
  10. Matthew Becker1's Avatar
    Do you have, or have access to, apps that will allow you to edit the APN manually?
    04-25-2014 08:45 AM
  11. Pavlov Effect's Avatar
    yes; it is same
    04-26-2014 10:50 AM
  12. JWSHale's Avatar
    Sorry - managed to forget to subscribe to this thread and hadn't realised there were replies!!
    @neo158: I'm about to try a factory reset, as there are a couple of other niggles with 8.1 that I'm hoping will go away.
    @Matthew Becker1: AFAIK, I don't have any apps that would let me edit the APN settings.
    04-27-2014 05:16 PM
  1. Boot Loop and No Boot problem solved.
    By ericmarx9 in forum HTC 8X
    Last Post: 10-19-2014, 11:17 AM
  2. Cortona & Image search problems
    By missionsparta in forum Cortana
    Last Post: 07-05-2014, 10:40 PM
  3. ATIV SE switched to T-Mobile - Now I need the APN
    By Jacob F in forum Samsung ATIV SE
    Last Post: 04-27-2014, 05:41 PM
  4. Problem with Notifications
    By Soumavo Maitra in forum Windows Phone 8.1 Preview for Developers
    Last Post: 04-20-2014, 11:45 AM
  5. Problem zooming out on One Note app?
    By ebk14 in forum Applications
    Last Post: 04-19-2014, 03:42 PM
