12-16-2016 07:34 AM
2,690 ... 8081828384 ...
tools
  1. lexrsk's Avatar
    First 'bug'? Or it's just me?
    "AccuWeather - Weather for Life" - application does not work with the new firmware :-(
    (8.1.1, no PfD, latest Samsung firmware)
    Same here running non Pfd.
    FW: 2424:14.9.4
    OS: 8.10.14203.306
    03-27-2015 04:35 AM
  2. Boris NevermorE's Avatar
    Have not used this application before. Just installed now to check, and it is not working (crashes immediately after start). No PfD, latest firmware.
    Works fine on mine, just installed to check this. Doesn't crash, but i don't use it, I am using Vieather. I'm on Official 8.1.1, no PDF.
    OS Version: 8.10.14157.200
    FW Version: 2424.14.9.4
    03-27-2015 04:36 AM
  3. tofmin's Avatar
    Yep, with 2424.14.9.4 works like a charm. With new one, app crashing...
    Thanks guys for your time!
    03-27-2015 04:41 AM
  4. nauman73's Avatar
    Boris, the issue is probably with the particular application, i.e. "AccuWeather - Weather for Life", and not with all weather applications. Vieather is running fine on my set while "AccuWeather - Weather for Life" is not.
    03-27-2015 04:43 AM
  5. nauman73's Avatar
    Sorry.. I think I did not read your message carefully.. Please ignore my last message
    03-27-2015 04:44 AM
  6. Boris NevermorE's Avatar
    Oh you mean, with the new one that some users on ATO got it? Yeah, i haven't got that update yet, I am on NEE.
    03-27-2015 04:47 AM
  7. Boris NevermorE's Avatar
    You have been forgiven :) LOL
    03-27-2015 04:48 AM
  8. nauman73's Avatar
    Yes, with the latest firmware released couple of days ago (which I have got as well), the "AccuWeather - Weather for Life" app is crashing.
    03-27-2015 04:50 AM
  9. Boris NevermorE's Avatar
    oh, yeah, i get it now. Thanks.
    03-27-2015 05:02 AM
  10. lukas_ita's Avatar
    Can some one confirm bootloop is gone with last FW? I read this in polish the forum. If it is gone i want to change reg key to receive Cortana in Italian without change any file
    03-27-2015 05:16 AM
  11. grozaman's Avatar
    YES. The latest FW solved problem with bootloop. How many times to repeat?
    megadragon998 and WinSammie like this.
    03-27-2015 06:05 AM
  12. megadragon998's Avatar
    Lol guys, such an *****, i already have .306 installed because i had PfD turned on when receiving update from samsung so it installed automatically :D
    WinSammie likes this.
    03-27-2015 06:10 AM
  13. grozaman's Avatar
    If you want to get the latest FW you can simply change one key at register.
    HKLM\SYSTEM\Platform\DeviceTargetingInfo\PhoneMobileOperatorName
    Change to "000-AT". After that go and check update.
    This is hack works only on DNI3. DNI4 doesn't get update. You can find this in Diagnosis using *#1234# code.
    If you don't know how to edit.
    03-27-2015 06:16 AM
  14. cedogares's Avatar
    Yes, with the latest firmware update you can safely update to 14219.
    With data in action center? How do i do that? I got official 8.1 then switched to PfD to get 8.1.1 and now i'm stuck on 14203.306 ..
    03-27-2015 06:32 AM
  15. NiteLordz's Avatar
    Hello, i am a developer for AccuWeather, and I was just reading through this thread. I was hoping you guys who are experiencing the issue would be able to help me out with a few more details.
    1) Can you confirm for me, that the application was working fine prior to the updated firmware
    2) Post firmware update, the application would crash immediately
    2a) Would the spash screen (AccuWeather on a light blue background) show ?
    3) What version of the application is currently crashing
    4) Have you tried to uninstall and re-install the application from the store?
    Thanks much guys, and i will be working to get this resolved as soon as possible.
    03-27-2015 07:29 AM
  16. Boris NevermorE's Avatar
    Wow, now that's what I call a devoted developer, kudos to you sir.
    Ok guys here is your chance to talk to the developer, write your comments here.
    Anyway, I too have some suggestions and reports but I'll do that from the app feedback link. :)
    03-27-2015 07:41 AM
  17. NiteLordz's Avatar
    Update, it would appear the issue revolves around our Satellite tile layer. Can you verify that you can view locations that have radar, but as soon as you try to view a satellite tile layer, that is when it crashes.
    Thanks much
    03-27-2015 07:59 AM
  18. tofmin's Avatar
    ad 1. Yes. Works like a charm before Samsung firmware update.
    ad 2. 2424.14.9.3 or 2424.14.9.4 - no problems. New update 2424.15.3.2 and crashing.
    ad 2a. Yes. Splash screen and application closes immediately.
    ad 3. Latest one from store. Version 2.7.0.16.
    ad 4. Yes. Few times.
    PS. Thanks!
    NiteLordz likes this.
    03-27-2015 08:10 AM
  19. NiteLordz's Avatar
    PS. Thanks!
    Can you tell me what your default location is ? if it is a location that does not have Radar coverage, then your issue is currently being worked on. And it is not related to the Samsung firmware update.
    If i can get you to uninstall the application, re-download it, and upon startup, do not turn on GPS, but instead, put in a location that has Radar coverage.
    ex. San Francisco, CA or New York, NY. I would imagine that the application would load, based on the information that is currently presented to me.
    Thanks much for your cooperation and help, and know that this is being looked at by our QA department.
    03-27-2015 08:15 AM
  20. tofmin's Avatar
    Very small village in Poland, Europe. I must set my location manualy cause even gps shows it wrong :)
    And, afair, there's no radar option for me.
    tap4wp
    03-27-2015 08:49 AM
  21. maki01's Avatar
    Accuweather app doesn't have anything with latest firmware. I am on 2424.14.9.4 firmware (no PfD, CSC NEE) and app is crashing. I tried uninstall after that install but is still crashing, also i change the start screen color but same thing happening. App splash screen is ok, after that loading another window with current city and after that crashing. My city is Skopje, Macedonia. Gps is turn Off. Cheers
    03-27-2015 09:10 AM
  22. NiteLordz's Avatar
    Thanks for your reply, and this issue appears to be related the satellite tiles. I just test Skopje, Macendonia and the application is now working. It may take an hour to populate the cache with the appropriate data. If this problem persists after an hour, please report back.
    Thanks again for everyone's help.
    maki01 likes this.
    03-27-2015 09:24 AM
  23. maki01's Avatar
    Now everything is OK. I just open app and didn't crash. Thank you for your fast responding. :)
    03-27-2015 09:27 AM
  24. Driesb's Avatar
    I am on the latest firmware (PfD, CSC ATO) and have no problems with Accuweather. Functioning normal. Location: The Netherlands
    03-27-2015 09:28 AM
  25. grozaman's Avatar
    Samsung have only one official update - 14157. It's WP8.1.1. You can edit register and get the latest PfD update for Lumias - 14219. With data in action center.
    03-27-2015 09:55 AM
  1. Nokia Lumia 521 no picture messages after update??
    By Casey Marte in forum Windows Phone 8.1
    Last Post: 11-18-2014, 08:04 PM
  2. Lumia 521 update problem.
    By PachecoCorporationCeo in forum Ask a Question
    Last Post: 11-18-2014, 01:01 AM
  3. Battery saver after update doesn't show correct usage?
    By rpac78 in forum Ask a Question
    Last Post: 11-14-2014, 09:36 PM
  4. Why wont my Nokia 520 download the 8.1 update?
    Last Post: 11-14-2014, 06:10 PM
  5. Hulu Plus gets rare Windows Phone update, adds voice search to app
    Last Post: 11-14-2014, 04:42 PM
