The Windows 10 April 2018 update has arrived! Get the new Dell XPS 15, starting at $999.99
01-04-2018 11:29 AM
717 ... 678910 ...
tools
  1. Mika Tiilikainen's Avatar
    Similarly here, and I don't notice the difference from the previous version, it still works. :-)
    12-19-2015 02:50 AM
  2. luisfarelo's Avatar
    Hello guys, sorry to bother but could anyone provide a link with instructions to install W10 mobile on the Ativ S (European version). Thanks in advance.
    12-19-2015 05:53 PM
  3. Bokkie's Avatar
    A t899m?
    12-20-2015 03:05 AM
  4. luisfarelo's Avatar
    No, i8750
    12-20-2015 06:27 AM
  5. Skyjouby's Avatar
    Just look at the last pages (only 7 pages on this topic).
    Everything is well summarized and quoted 3 or 4 times.
    Have a nice day
    12-21-2015 02:40 AM
  6. ranseb's Avatar
    Hey everyone, maybe some good news from AdDuplex (see end of item 14):
    AdDuplex Windows Phone Statistics Report - December, 2015
    vikz95 likes this.
    12-22-2015 10:53 AM
  7. Toutencarton's Avatar
    I think this doesn't tell us anything. A few of us have upgraded our Ativ S to W10M. This means we are part of the AdDuplex results.
    What could really indicate that there is an upgrade coming is if AdDuplex had spotted a few Ativ S on W10M with a higher firmware number than ours (> 15.3.2). Unfortunately, we have no information about this.
    Skyjouby and Tien-Lin Chang like this.
    12-22-2015 03:39 PM
  8. Tien-Lin Chang's Avatar
    Hi, does anyone updated to w10m got device hub or gadget app? Cos I read about this and couldn't find it in my phone (hacked to Nokia with no model change to get 10586 then trying 830/925/920 model to see if get this app updated but nothing happened). Thanks
    12-25-2015 06:49 AM
  9. luisfarelo's Avatar
    So, as Samsung has no intention of upgrading Ativ S to W10 Mobile, and evend W10 Mobile being a mess right now, I sold my Ativ S. It has been a good ride but timeto move on. My Asus Laser is coming my way.
    01-01-2016 03:11 PM
  10. j1527316's Avatar
    Hello, where I can find any verified guide step-by-step how to upgrade my Ativ S i8750 to W10m? Thanks.
    01-02-2016 04:57 AM
  11. Mitja358's Avatar
    Just read all previous pages ...
    01-03-2016 09:10 AM
  12. bugmenot6's Avatar
    Running W10M now for 2 weeks - runs pretty well - not that well as 8.1, but well enough to keep it running with W10M.
    Unfortunately I noticed some drawbacks - but nothing that couldn't be solved ;)
    Personally I found 1Shot Camera to be a good alternative to take photos, especially since the app does not require that much permissions as other apps (OneShot, 360, etc.) do. Also "1020 Camera" is good, even though not that feature rich.
    Only thing I couldn't find out yet is how to change the default camera app - no app, except the windows camera app, is showing under the settings for the default camera setting in the drop-down list :( Isn't there a registry key to tweak that?!
    Since I can't use Cortana with my phone language UI and region settings (English UI with German region) I really miss some features like music recognition which aren't available then without Cortana ("Cortana isn't support in the region and language you've selected"). Luckily there are apps like Shazam to help here.
    Cheers!
    PS:
    For German readers (like me), here's a great guide how to upgrade to W10M:
    goo.gl/TDUu8C
    Maybe a translator helps also English readers which want a really good step by step guide for how to upgrade to W10M.
    01-04-2016 12:28 PM
  13. Tien-Lin Chang's Avatar
    Well I think only Lumia devices can change default app, I had a HTC 8S and ATIV S and I saw this setting item years ago during the wp8.0 era yet still useless as they are now....
    Just hope MSFT can get rid of these small raw edges this time and do it right.
    01-06-2016 03:37 AM
  14. assyriska's Avatar
    found a solution for using the proshot app as default camera app, but i don't know if it is illegal or not. If anyone want to test it, just bing/google proshot mod winphonehub.
    PS:
    goo.gl/TDUu8C
    thanks for linking my tutorial. when i find some time, i can translate it into an english version.
    01-08-2016 06:48 PM
  15. Mitja358's Avatar
    Grab the latest .63 Windows Insider update.
    01-09-2016 05:58 AM
  16. lukas_ita's Avatar
    It's not illegal... Copy and paste the guide!!
    01-10-2016 01:08 AM
  17. Rimil0uz's Avatar
    After installing last update .63 battery consumption is much better. From 10:00 am to 20:16 with light use. (Answer a couple of whatsapps, wifi on, 3g/2g on, BT off except for a 40 min travel in car). Battery went down from 100% to 83% o.O. Not bad for a more than 2 yo device... Overall I'm quite happy with my device.
    01-10-2016 01:19 PM
  18. Bokkie's Avatar
    There's the issue about the camera button (standard app that can't be changed), because the focus in the standard app doesn't work for most people. But that might be solved I see :)
    What are other specific issues? I hear ppl praising windows 10 but also some people saying it's not as 'good' as 8.1, but I would like to know what the issues are.
    01-10-2016 03:50 PM
  19. dan16's Avatar
    It is far better than 8.1 in almost every aspect even without a dedicated firmware. The boot has even improved, I do not find delays while charging anymore. I am happily running .29 now, waiting for a final reliable version in the slow ring. Speaking about issues, the camera focusing is the most important: also bing translate and office lens are affected by that. Office lens can be used also as post processing of photos made by camera 360 sight, though.
    The flash happens to be not quite perfectly synchronised and in the very first hours after upgrading it caused 3 reboots to me (just temporary issue).
    The video recording (are there alternative apps?) should be affected by the focus issue, but that is not so bothering.
    You have no more vibration on pressing buttons, that is just a matter of habit though (I actually did not like those vibrations).
    The battery life is maybe a bit less than old 8.1.
    When unlocking the phone through the start button it happens to enter the half display mode involuntarily, sometimes.
    That is all, I think.
    Edit: I forgot that the video playback in portrait mode has often a "black" rendering issue. You rotate the phone and the landscape mode is ok.
    Bokkie and Tien-Lin Chang like this.
    01-20-2016 01:47 AM
  20. Bokkie's Avatar
    Thanks! I guess I'll try to update my t899m when I've got some spare time :) The old Internet Explorer is bugging me...
    01-20-2016 05:35 AM
  21. Exotic Hadron's Avatar
    Thanks. Am I getting it right that in two lines updating to 10586.71 leads to:
    • Camera not working
    • No haptic feedback for hardware buttons
    If there's no focus for camera how come it could be used for making reliable photos? Or did you manage to use some other camera apps? Which ones then?
    Office lens with its limitation of 10 photos per bundle and requirement to store photos to OneNote doesn't look promising...
    02-04-2016 07:37 AM
  22. Exotic Hadron's Avatar
    The best one I know, sorry Windows Central, can be found here.
    02-04-2016 07:39 AM
  23. Skyjouby's Avatar
    Look at previous pages instead of questioning and giving a stupid answer...
    02-04-2016 11:38 AM
  24. Dave Velo's Avatar
    Did the registry hack and my ATIV S now shows an update for 10.0.10586.29. I then reedited the registry back to default and rebooted. The phone still shows the update. I'm tempted to follow through but will wait until summer. BTW, has anyone updated to this version? If so, did your phone continue to update to the latest Redstone releases?
    02-10-2016 02:14 AM
  25. sirozan's Avatar
    When using the new production preview ring of windows insider, i get the new .107 build offered as an update (i'm still on wp8.1), but after downloading i always get the error 801882c2 :(
    Can someone here confirm this/ knows what to do here?
    PS: not using any hacks or tricks here like imitating some Lumia, just got this as a normal update from stock 8.1, but with said error
    02-11-2016 02:07 PM
717 ... 678910 ...
  1. Vote for bringing NuAns to USA!!
    By FAHMI BASSEM in forum Upcoming & Rumored Phones
    Last Post: 06-13-2016, 04:29 PM
  2. Lumia 950XL - Windows 10 10596.63 - Background App Use.
    By Belushi Schweeft in forum Microsoft Lumia 950 XL
    Last Post: 01-09-2016, 10:22 AM
  3. Replies: 1
    Last Post: 01-08-2016, 07:07 PM
  4. When will WP 10 officially announced?
    By stevenkhan168 in forum Ask a Question
    Last Post: 01-08-2016, 06:34 PM
  5. Windows 10 Realtek audio question?
    By AlexCcc in forum Windows 10
    Last Post: 01-08-2016, 06:11 PM
