1. blckDTshadow's Avatar
    Hey,
    The back of my Ativ S just splintered. Not too bad, but I would like to replace it. On Amazon here in Germany it's 13 though. Has anyone a hint, where I might be able to get a cheaper one?
    Thanks ahead.
    PS: On a side note my phone is getting slow. Is it worth to reflash?
    10-14-2015 02:19 AM
  2. Toutencarton's Avatar
    Hey,
    13€ is ok from my point of view.
    I replaced the full rear-housing of my Ativ S and the lowest price i found for the back cover was 10€ (add 5€ for the shipping fees).
    Note that the back cover available for 4-5€ on alibaba are fake ones.
    No need to reflash. A reboot is a good start. If it's still slow, try a hard reset.
    10-14-2015 11:32 PM
  3. ptrkhh's Avatar
    Is it much different than the original one?
    10-31-2015 06:59 PM
  4. anon(8316658)'s Avatar
    depends on the quality,
    some of them dont have the SAMSUNG logo on it
    others are too big or small on the edge and dont fit tight
    10-31-2015 07:09 PM
  5. Toutencarton's Avatar
    For the battery cover, I don't think this will be a problem (just check the clips position).
    For the rear housing, it is usually one because the rear housing of your phone is its antenna. And the first one i ordered was missing connectors.
    Then I ordered an official one. ^^
    11-01-2015 11:41 PM
  1. Question for insiders
    By CygnusOrion in forum Windows 10 Insider Preview
    Last Post: 10-24-2015, 01:15 AM
  2. Replies: 1
    Last Post: 10-15-2015, 04:36 AM
  3. Code Compilers for Windows Phone
    By MiguelCarino in forum Developers Corner
    Last Post: 10-14-2015, 01:43 AM
  4. Are there different layers in Insider Preview Builds for Mobile?
    By Pradeep John in forum Windows 10 Mobile Insider Preview
    Last Post: 10-14-2015, 12:08 AM
