Shop HP’s Memorial Day Sale:Save up to 61% on PCs and more!
05-11-2014 03:32 PM
375 ... 12131415
tools
  1. BrooklynGal's Avatar
    I was told I new a replacement.
    05-06-2014 08:54 AM
  2. Novron's Avatar
    Verizon didn't replace it right there? Odd.
    05-06-2014 01:38 PM
  3. BrooklynGal's Avatar
    Actually, the rep was busy with other things, such as counting is register cash to start the day. He had other customers who arrived after me addressed before me, so I left. I was running for work.
    I'm going to go back to the location where I purchased it.
    05-06-2014 01:59 PM
  4. BrooklynGal's Avatar
    Regarding the "cloud storage", are the 7gb in addition to 32gb onboard the Icon?
    05-06-2014 02:01 PM
  5. Nogitsune Micah's Avatar
    yep. onedrive is 7 gb plus the icons 32 gb storage
    BrooklynGal likes this.
    05-06-2014 02:17 PM
  6. BrooklynGal's Avatar
    Brought the Icon back to the Verizon store where I purchased it (which in my opinion has some really good tech people) and voila, the phone is fine. The gel-type screen protector was the culprit, interfering with the sensor to cause the screen to remain dark during calls. The protector was not covering the sensor, but I assume it was too close to it. He gave me a different one to try, which caused the same results. Later today, I'll have to cut some off to help avoid the area near the sensor as best I can.
    05-07-2014 09:03 AM
  7. Mmazeo's Avatar
    Almost decision time and I'm still torn.
    Bulky yet classy vs thin yet ugly
    32gb vs IR blaster
    MS support vs no support
    05-07-2014 02:41 PM
  8. Tony_Offends_U's Avatar
    32gb vs IR blaster
    How you figure no support? You know the ATIV S got GDR 1,2,&3 before the Lumias. Firmware and apps regularly updated. Stop with the nonsense ppl.
    05-07-2014 03:26 PM
  9. Mmazeo's Avatar
    That's what Micah told me
    05-07-2014 04:05 PM
  10. PuckCowboy's Avatar
    32gb vs IR blaster
    Also, I might make a comparison more like:
    32gb vs 16gb up to 134GB (with 128gb SD)
    Nokia IOS Low Light Camera vs IR Blaster
    The classy thing is subjective to me. I think the ATIV SE with the unassuming silver polish is much classier than Icon. Just personal preference.
    snowmutt likes this.
    05-07-2014 05:10 PM
  11. Tony_Offends_U's Avatar
    All of this is, people just trying to pass preference off as law.
    A895 likes this.
    05-07-2014 07:01 PM
  12. Mmazeo's Avatar
    I want no part of dealing with an SD card.
    05-07-2014 08:47 PM
  13. PuckCowboy's Avatar
    Why, have you had a bad experience with them? I've had my 64GB in my Nokia for a year and a half now with no issues at all. Popped it in and never had to worry about it again.
    05-08-2014 02:40 AM
  14. Novron's Avatar
    There are some minor issues with certain apps in 8.1 and SD cards with the SE. The podcast app nor the Music app will play from SD. Just sits there with a loading screen.
    Looks like a soft reset, card scan, and all is good again.
    05-08-2014 08:15 AM
  15. BrooklynGal's Avatar
    I'm torn as well.
    05-08-2014 10:39 AM
  16. BrooklynGal's Avatar
    I'm torn as well. I'm concerned with all the "glitches" I read concerning the Icon. Then again, since the ATIV SE has not been reviewed by many and has not been around that long, who is to say it won't have any. I know the 8.1 update has not been handled well by the ATIV SE.
    So far:
    Icon Pros..brighter screen (especially when I use Google search), more detail in photos, built in FM radio.
    ATIV SE Pros..SD card, removable battery, a touch faster screen, home button.
    According to the storage check overview detail on the Icon, out of the 29gb available, I have just about 21gb remaining. I'm a bit concerned about that.
    Will purchase a blue tooth headset with built fm radio and test it with the ATIV SE.
    A895 likes this.
    05-08-2014 10:48 AM
  17. PuckCowboy's Avatar
    Isn't 8.1 still just a "Developer's Preview"? I don't understand how this is an official negative for the ATIV SE seeing as it's not an official release, especially not for the ATIV SE specifically. I will hold judgement on 8.1 for the ATIV SE or any other Windows Phone devices until the official updates.
    05-08-2014 11:16 AM
  18. A895's Avatar
    Same here. I wouldn't jump into 8.1 in the first place seeing how the most common complaint is battery life takes a hit.
    Sent from my XT907 using Mobile Nations mobile app
    05-08-2014 11:29 AM
  19. OHardy's Avatar
    I would go with the ATIV SE hands down. It would be a day one buy for any Sammy or HTC WP8 Flagship phone on Tmobile. My 925 was one of my worse upgrade decisions, it offers nothing original from my 8X or unlocked ATIV S.
    Could you kindly post the specs & features of the NL925 & HTC 8X for comparison please?
    05-08-2014 11:39 AM
  20. Matthew Becker1's Avatar
    Yes. It's not a consumer release, so people shouldn't be so shocked that it doesn't work well on their main device.
    05-08-2014 11:48 AM
  21. BrooklynGal's Avatar
    My mistake and thanks for pointing this out...I didn't know that the 8.1 upgrade was a "Developer's Preview." Features/glitches can certainly improve once the official release happens.
    Thanks!
    05-08-2014 01:40 PM
  22. Novron's Avatar
    Thanks!
    Yes, all the hardware glitches will get resolved with the firmware updates that roll out along with 8.1 when it's officially released. Samsungs, Nokias, they'll all get fixed. If they didn't, there is no way in hell the carriers would let any OEM's do direct updates anymore.
    05-10-2014 07:54 AM
  23. Nogitsune Micah's Avatar
    Technically they do "support" their devices by updating them but aside from a few hardware differences, very little about them make them better than their competitors especially since when buying a Samsung or HTC you sort of get the base windows phone experience compared To a more customized user experience. So I should say "limited support" for Samsung which is true
    05-10-2014 08:11 AM
  24. Nogitsune Micah's Avatar
    I am the same way. I mean I use it now simply because my 1520 has only 16gb but I would be fine with the icons memory. SD cards always seem to get screwed up for me and I'm not the person who feels the need to keep popping two or three different SD cards in my phone nor do I need a128 GB of storage which imo is overkill ro an extreme.
    05-10-2014 08:14 AM
  25. Nogitsune Micah's Avatar
    So far:
    My boyfriend hasn't installed the dp on his icon but for me this is my second time doing it with Nokia phone(1020 and 1520).
    The pros imo do outweigh my cons.
    My main issues were the reboots(which have stopped) and the extremely flaky wifi signal and mobile network on my 1520. But this comes from using a beta software thus I dont blame my phone as it was fine with it and it is bearable just a mild annoyance.
    My rroommate does have dp on his icon and absolutely loves it. No complaints from him.
    It is a shame not many people are about the ativ se. I can understand why of course but I do want to see a professional reviewer talk about their take on the device. Even Wpc hasn't done one or winbeta and wpu, which says a lot.
    05-10-2014 08:20 AM
375 ... 12131415
  1. Lumia 930 is 6 months behind the times
    By camstreet1 in forum Nokia Lumia 930
    Last Post: 05-01-2014, 05:13 PM
  2. lumia 620, updated to lumia black
    By majdi suliman in forum Windows Phone 8
    Last Post: 04-05-2014, 05:51 AM
  3. How to handle these issues without an SD card on Lumia flagships
    By Jacks Blacks in forum Nokia Lumia 930
    Last Post: 04-04-2014, 09:52 PM
  4. Lumia 520 don't have memory after Asphalt 8 update.
    By Revolt3421 in forum Nokia Lumia 520
    Last Post: 04-04-2014, 02:40 PM
  5. Replies: 3
    Last Post: 04-04-2014, 12:54 PM
