1. peacefulberry's Avatar
    Does the Ativ SE have swipe/tap issues like the 1520? Also, to those that may have both...what do you think causes this issue?
    mary beth hale likes this.
    05-10-2014 10:59 AM
  2. BrooklynGal's Avatar
    I'm not experiencing any major issues. Sometimes if I swipe down to view some settings, it may take 2 swipes.
    peacefulberry likes this.
    05-10-2014 05:11 PM
  3. Novron's Avatar
    Don't have any swipe issues on the SE. Once every couple days or so the touch screen stops responding but that's an 8.1 issue. Soft reset fixes it. No screen issues on my Icon at all.
    05-10-2014 08:09 PM
  4. chinesepiratefood's Avatar
    No issues on mine, never had the 1520 though so don't know exactly what to look for.
    05-15-2014 04:19 PM
  5. queshaw's Avatar
    I have a sm-750v and have not figured out how tap to open works, or it doesn't work. So, I have not managed to open files from URLs. I see no save as option or equivalent to right-clicking in a desktop UI. The tap to open page displays. When I tap, the same page displays again. So far I have tried this with PDFs and Excel documents.
    06-07-2014 05:21 PM
  6. queshaw's Avatar
    Oops! Resetting the phone fixed this.
    I don't think I had installed any apps at all, before experiencing this. So, maybe the OS was updated? I don't know.
    The phone was purchased from Verizon.
    After resetting the phone, when I tapped, it prompted me to download an App to view the PDF. It was an excel file from a different version of excel that I tried after resetting. So, I don't know if not prompting for an App is related to tap not working for an excel file before.
    06-11-2014 02:36 AM
  1. Do games run smoothly on your SD card on WP8.1 ?
    By Lance_WPCentral in forum Windows Phone 8.1 Preview for Developers
    Last Post: 01-05-2016, 04:43 AM
  2. GT-I8750 ATIV S battery upgrade from GS4
    By palaczy in forum Samsung ATIV S
    Last Post: 05-21-2014, 03:30 PM
  3. My Phone is charging on it's own/off the charger
    By PDaniels1 in forum Nokia Lumia 920
    Last Post: 05-10-2014, 11:48 AM
  4. 3.5 hot fix on the way
    By Boris Gong in forum Applications
    Last Post: 05-10-2014, 09:52 AM
  5. Replies: 1
    Last Post: 05-10-2014, 06:57 AM
