Verizon lists the Ativ as having bluetooth 3.0. Is this true? I would have thought it would have 4.0 with the rest of the hardware being so up to date.
Samsung lists it as 3.0 on it's website also.
They also list SDHC slot but it has an SDXC slot. They also list a lower pixel rating for the camera than it really has.
If it does have 3.0, how does this translate into real life use re: What does 4.0 do that 3.0 doesn't?
It means nothing if the device you're connecting to doesn't support 4.0. Besides, all BT is backward compatible and BTW, 4.0 is basically low energy and faster transfer speeds.
Thanks so much for the answer. Felt stupid asking, but figure it's the only way to educate myself.
I've seen some of your posts regarding the Ativ S, I'm waiting on one to arrive so I'd like to pick your brains regarding 8.1 and any issues I need to look out for.
Thanks, Fernando.
So you're saying it doesn't have 3.0?
