1. Trevor Halsey's Avatar
    Hey everyone, I just ordered the SE as my main driver, which should I should be able to pick up Monday or Tuesday. I can only assume that the method of installing it will use the same native toast launcher that worked for the odyssey and now this device.
    The first requirements is that your device is DevUnlocked and you are still using GDR3.
    The rest of the procedure will be edited in once I get the ATIV SE shipped to the store.
    DrRambone likes this.
    07-18-2014 10:44 PM
  2. Trevor Halsey's Avatar
    Well, the usual exploit for the ATIV S, the ATIV S Neo, and the ATIV Odyssey no longer works for the ATIV SE. There might be some new findings sooner or later, but the only possible method at this time is a custom rom. I'll make a new post when I've been given more information on how it will work.
    08-08-2014 10:38 PM
  1. Sd card issue with the Lumia 520.
    By Tyrone lio in forum Ask a Question
    Last Post: 03-28-2015, 05:08 PM
  2. Firmware Updated for Lumia 635
    By klewis2046 in forum Nokia Lumia 635
    Last Post: 07-19-2014, 02:41 AM
  3. Twitter for Windows Phone gets an update, no new features to be seen
    Last Post: 07-18-2014, 10:42 PM
  4. Lumia Cyan comes to the Lumia 925 on O2 in the U.K. and to the Lumia 625 on Ireland's Meteor
    Last Post: 07-18-2014, 07:30 PM
