1. infool7's Avatar
    Is anyone using this device on the At&t network? What are the drawbacks / advantages(if any)?
    08-13-2014 01:44 PM
  2. xandros9's Avatar
    Assuming its any bit like how other VZW Windows Phones' behaved, it will work, but MMS may not work/may need some tweaking, data probably will work, maybe APN needs to be tweaked too. I doubt you'd get LTE. I could be wrong.
  3. xandros9's Avatar
    Laura Knotek likes this.
    08-13-2014 10:12 PM
  4. Trevor Halsey's Avatar
    The bands included don't line up. LTE won't work.
    Laura Knotek and xandros9 like this.
    08-13-2014 10:58 PM
  5. GTF696's Avatar
    LTE Works on t-mobile.
    AT&T uses 700 and 1700 Channel 4 so I believe it would work, however I haven't tried it.
    09-30-2014 01:21 AM
  6. Fred Wilson2's Avatar
    I'm using it on AT&T.
    In my area LTE does not work, though that's not important to me at all.
    Incoming MMS does not work, but you can send MMS.
    Also Internet tethering does not work.
    Everything else is fine. You have to manually set the MMS to get the outgoing MMS to work, however incoming will not work.
    I have since learned that Verizon locks down, via firmware, the MMS and Internet sharing on their LTE phones.
    The GSM is unlocked.
    Fred
    xandros9 likes this.
    09-30-2014 08:23 AM
  7. Fred Wilson2's Avatar
    I'm going to put my ATIV SE up for sale as I'm moving (retiring) overseas.
    Can't post in the Classifieds yet :)
    Fred
    10-04-2014 02:35 PM
  8. ATIV_S's Avatar
    Hey Fred,
    Thanks for your information, that helps. Which WP OS are you using that's giving you the MMS and Internet Sharing problems, is it WP8 or WP8.1 Developer Preview? I would totally love to use this phone on At&t's network too, but if there's isn't a fix for MMS then I might reconsider. I can careless with Internet Sharing since I don't use that. Thanks!
    10-14-2014 12:48 PM
  9. Fred Wilson2's Avatar
    Just the WP8 that came with it.
    XDA devs, after digging around there, it appears that while Verizon does have the GSM unlocked (required by the FCC), they do lock down the MMS and internet sharing.
    Fred
    Hey Fred,
    10-14-2014 08:59 PM
  10. ATIV_S's Avatar
    Thanks for the response Fred. Do you know if XDA Dev have a code to unlock it by any chance? Also, do you know if installing WP8.1 Developer Preview will make MMS work for the ATIV SE?
    10-16-2014 02:53 PM
  11. Fred Wilson2's Avatar
    No, I don't know. Never checked.
    Fred
    10-23-2014 06:53 PM
  1. Has Anyone Received CYAN on Metro PCS Lumia 521?
    By WINDOW LOVIN in forum Nokia Lumia 521
    Last Post: 10-02-2014, 12:47 AM
  2. Replies: 14
    Last Post: 10-01-2014, 07:56 PM
  3. Why isn't my sd card working?
    Last Post: 09-30-2014, 05:30 AM
  4. Does anyone have trouble for Cortana to work after the newest update for WP 8.1?
    By Joshua Liu in forum Windows Phone 8.1 Preview for Developers
    Last Post: 09-29-2014, 09:44 PM
  5. Why my "share connection" doesn't work?
    By LeandroPF in forum Ask a Question
    Last Post: 09-29-2014, 09:06 PM
