1. Sean Dailey's Avatar
    My ativ se seems to be charging very slowly, ie 7-8 hrs for a full charge. Anyone else having this issue? Also, what good is a swappable battery if I can't find anywhere that sells the battery. Anyone have any luck on this one?
    11-18-2014 06:35 AM
  2. Sean Dailey's Avatar
    After a little more research, it looks like this uses the same battery as the S4. I bought an extra battery and dual charger, which should resolve my battery issues. I was spoiled by my 8x, which charged very fast and sipped battery life.
    xandros9 likes this.
    11-18-2014 08:49 AM
  3. xandros9's Avatar
    Also make sure the charger you're using puts out at a sufficient amperage. 1-1.5 or so. 2 is ideal.
    7-8 hours is suspiciously abnormal, even for the slower wireless charging on some phones.
    11-18-2014 10:22 AM
  4. Sean Dailey's Avatar
    I do use the 2A charger that came with the device, and a 2.1A portable battery charger with the same results. I'll see if I get and different results with the new battery that's on the way.
    11-19-2014 06:53 AM
  5. Fred Wilson2's Avatar
    Mmmm, when I had the ATIV SE for a week or so, I compared its battery to the one in my S4 and they were not the same.
    Not the same physical size and shape.
    Fred
    11-19-2014 01:21 PM
  6. Sean Dailey's Avatar
    Well, I looked it up by part number, and the one I ordered said it was a battery for an s4. It hasn't come yet, so ill post definitively when I get it.
    11-19-2014 07:30 PM
  7. Sean Dailey's Avatar
    received the battery today, part number B600BZ, and it fits perfectly and is the exact same battery that came with my Ativ SE. on Samsung's website, it's listed to work with the S4 and S4 active.
    11-22-2014 08:49 PM
  8. Sean Dailey's Avatar
    The charging dock for the s4, however, will not work with the ATiv se. The spare battery slot on the back is what I bought it for, however.
    11-26-2014 01:06 PM
  1. 730 battery single sim vs dual sim
    By Nikhil Bhargav in forum Nokia Lumia 730 & 735
    Last Post: 12-20-2014, 03:40 AM
  2. Battery Wear at 101.6% Is that normal?
    By nightspark in forum Microsoft Surface Pro 3
    Last Post: 12-06-2014, 08:49 PM
  3. Battery Life Since Last "Critical" Update
    By garak0410 in forum Nokia Lumia Icon
    Last Post: 11-30-2014, 12:29 AM
  4. Why is my Lumia Icon Battery Draining at twice the normal rate?
    Last Post: 11-17-2014, 10:44 AM
  5. Why is my battery draining so quickly on my Nokia Icon?
    Last Post: 11-17-2014, 09:32 AM
