11-11-2015 09:34 PM
126 12345 ...
tools
  1. Ralph Marius's Avatar
    Thanks, It doesn't show me a update :( I was on the Preview so I'm wondering if this will be a issue.
    03-02-2015 02:52 PM
  2. fletch33's Avatar
    i have had a thread on this going on HERE that i am updating OP with screen shots etc..
    just letting you know
    03-02-2015 02:58 PM
  3. Rogozinski's Avatar
    Ok, looks like we with Ativ S won't get that app. :( Thanks for info!
    That's a pitty! Ativ S has already official 8.1 update?
    03-02-2015 02:58 PM
  4. Andy Belanger's Avatar
    Try disabling PfD.
    You mean by following the procedures in this post "How To Flash Windows Phone 8.0 GDR3 with Windows (Get Rid of Preview for Developers)", or were you talking about another way to disable it? I don't want to lose any of my data or apps, so I'm a little leery of following the removal procedures, unless it won't mess with any of that.
    03-02-2015 03:02 PM
  5. Ebuka Allison's Avatar
    Just turn it off. PfD uses different servers from regular updates, see if that's it
    03-02-2015 03:03 PM
  6. Jeemo's Avatar
    I haven't checked yet (and I am unable to), but you most likely can disable PFD and take the update OTA. My tutorial is probably not necessary. If you're having issues and you grow impatient that tutorial may help you, however, keep in mind you will lose your data. If you back up from PFD 8.1 and then flash, and then update OTA to 8.1, you SHOULD be able to restore your updates. Just don't log in with your Microsoft account until you've arrived at 8.1.
    03-02-2015 03:07 PM
  7. Ralph Marius's Avatar
    I uninstalled Preview for Dev and it still doesn't show any updates for me. Might have to flash it back. I'll just wait a bit longer to see.
    03-02-2015 03:10 PM
  8. Jeemo's Avatar
    If anyone on the Preview for Developers gets the update, let us know.
    I am unable to check, but you most likely can disable PFD and take the update OTA (after waiting for a bit). I have a tutorial to go back to Stock, but my tutorial is probably not necessary. If you're having issues and you grow impatient that tutorial may help you, however, keep in mind you will lose your data. If you back up from PFD 8.1 and then flash, and then update OTA to 8.1, you SHOULD be able to restore your updates. Just don't log in with your Microsoft account until you've arrived at 8.1.
    03-02-2015 03:14 PM
  9. Ralph Marius's Avatar
    From what I see the "The latest firmware build is now 2218.14.12.1 :" Mine is 2218.14.03.2 still.
    03-02-2015 03:24 PM
  10. fletch33's Avatar
    OP updated with screen shots
    Jeemo likes this.
    03-02-2015 03:27 PM
  11. Dusan Randj's Avatar
    Yes, not in all countries, but lots of us have official 8.1.1 from November or October.
    03-02-2015 03:57 PM
  12. Jeemo's Avatar
    I definitely have 2218.14.12.1, coming from stock. Try checking for another update.
    03-02-2015 04:09 PM
  13. Jeemo's Avatar
    We now have a section called "USB" in settings. This phone finally has IPoverUSB and VidStream!
    03-02-2015 04:13 PM
  14. EbenKent's Avatar
    As of 5:30 pm, I too have successfully updated from 8.0 to 8.1. Cortana is now available!
    03-02-2015 04:50 PM
  15. fletch33's Avatar
    so know i am curious to we have 8.1, 8.1.1 or 8.1.2 and my guess is we have just the first 8.1
    03-02-2015 04:56 PM
  16. xandros9's Avatar
    your screenshot shows "Windows Phone 8.1 Update" so that means that. AKA Update 1, GDR1, 8.1.1...
    03-02-2015 05:14 PM
  17. shirlA's Avatar
    I just got it and it's awesome!!! I was desperate for a calendar sharing now that I switched jobs (no longer able to keep it all on Exchange server) and now I can keep calendar and contacts in iCloud. The text swiping is super cool - both of these made me very happy!! Yay!
    03-02-2015 05:47 PM
  18. fletch33's Avatar
    on 8.0 didnt holding down the home button use to activate something? mine does nothing with a hold or double tap and seems like it should be useful to associate a function?
    03-02-2015 06:30 PM
  19. fatclue_98's Avatar
    I think you're remembering the app switching which was/is accomplished by holding down the back button.
    xandros9 likes this.
    03-02-2015 06:46 PM
  20. AgentDelta's Avatar
    On 8.0, holding down the home button would activate TellMe (the ability to give your phone voice commands). On 8.1, TellMe has been replaced with Cortana, and you hold down the search key instead of the home key to launch Cortana straight into listening mode. :)
    03-02-2015 07:11 PM
  21. fletch33's Avatar
    yes it would be GREAT to allow us the option to utilize that shortcut for something of our choice like an app
    03-02-2015 07:19 PM
  22. Williaml99's Avatar
    I had to roll back to 8.0 to get the update. Make a fresh backup before you do and you can restore after the official update. Thank you Verizon.
    If you wait you may eventually get it but I don't know. I had two of these devices and one had the PFD. The 8.0 device got the update immediately.
    Best Wishes
    Bill
    03-02-2015 07:27 PM
  23. Ralph Marius's Avatar
    How did you get it to roll back? I tried 2 computers and it will not work
    03-02-2015 07:39 PM
  24. Erik Sg's Avatar
    I agree, I would prefer to have Cortana accessed by holding the home button and search being the same from 8.0. Rather miss the Bing search screen...
    03-02-2015 08:24 PM
  25. Williaml99's Avatar
    http://forums.windowscentral.com/sam...evelopers.html
    I followed the instructions carefully. Don't forget to reboot after installing the drivers. I did not have to disable signed drivers as instructed.
    I went to backup settings before the procedure and chose backup now. The procedure worked as advertised. After successful rollback take the new update. After the update reset the phone and add your Microsoft account. It will find your new backup. If your backup setting include all options everything will be restored.
    Best of luck
    Bill
    03-02-2015 08:34 PM
126 12345 ...
  1. Replies: 5
    Last Post: 02-27-2015, 03:21 PM
  2. Why hasn't my 1520 received the Denim update yet?
    By Chaitanya_Kshirsagar in forum Ask a Question
    Last Post: 02-26-2015, 01:10 PM
  3. What features will the surface 2 update (kinda windows 10) have?
    Last Post: 02-26-2015, 12:22 PM
  4. Readly app for Windows Phone offers unlimited access to over 800 magazines
    Last Post: 02-26-2015, 12:11 PM
  5. OneDrive Windows Phone app update revamps its photo album and more
    Last Post: 02-26-2015, 11:42 AM
