11-11-2015 09:34 PM
126 ... 3456
tools
  1. Phoenix Jedi's Avatar
    How's the stability on the official 8.1 update? No crashing/etc like the preview?
    03-06-2015 04:09 PM
  2. Rogozinski's Avatar
    Till so far everything works excellent! No crashing and camera wirks great, especially the Ativ camera app is super! Batterly life seems also improved in my experience:)
    03-06-2015 04:43 PM
  3. fatclue_98's Avatar
    Okay, now that the official 8.1 is available for the SE, can we all agree this is the baddest WP on the block? This is coming from a 1520 owner who despises Big Red.
    Sent from my big *** Lumia 1520
    03-06-2015 10:34 PM
  4. berndts's Avatar
    I installed 8.1 on my Samsung Ativ SE last week - the good...I like 8.1 ...I used to have it over a year ago as the Dev Preview on my old Nokia 810...the bad ....now my phone reboots about 3 - 4 times a day without any warning....anybody else having this issue?
    03-07-2015 09:20 PM
  5. mary beth hale's Avatar
    If the Ativ SE had a GSM version, I would have purchased it without hesitation. My Ativ S was an absolute pleasure to use.
    fatclue_98 likes this.
    03-07-2015 09:25 PM
  6. ATIV_S's Avatar
    Thanks again Halev. Can you send and receive picture messaging's without using Whatsapp? Can you do me another favor? Sorry. Can you go into your "Settings" --> "APNs" --> "..." to see if you can select the "Add new access point?" or what information do you see there?
    03-08-2015 03:00 AM
  7. Rogozinski's Avatar
    Yes i can select new accesspoint. Also i tried to send normal sms and to add a photo. The photo appears in the message and then it says its an mms. I didn't send it but i think its possible...
    03-08-2015 04:01 AM
  8. DrRambone's Avatar
    No, even if the mms looks fine, sending gives an error.
    03-08-2015 08:36 AM
  9. ATIV_S's Avatar
    Thanks Halev! I appreciate your help. So what do you see after you select "add new access point?" Or can you take some screenshots if possible? If you can add new access point and saved it, then the MMS might just work. Can you do that test for me? You can delete it after it's saved and it should be no problem.
    DrRambone, do you have a ATIV SE on a different carrier network too? And it doesn't work after adding new access points either?
    03-09-2015 09:40 AM
  10. Rogozinski's Avatar
    I can not add a new access point because I have already one for my Dutch carrier. MMS works because my friend received the picture!
    03-09-2015 10:56 AM
  11. ATIV_S's Avatar
    Hey Halev, that's good news! So can you receive pictures from your friend then (not using whatspp)? ...So you can not add a new access point then? Is it blocked? How many access points does your Dutch carrier have listed under your APN setting? Sorry if I'm asking too much questions, just let me know and I'll stop ;)
    03-09-2015 12:47 PM
  12. Rogozinski's Avatar
    I dont know. Me and my friends always use Whatsapp for sending photos. MMS/SMS is not populair here in Netherlands. Abou the APN i already answered you and I am not so technical so I don't know everything about phones hahha. Maybe you should contact Verizon or Samsung.
    ATIV_S likes this.
    03-09-2015 02:10 PM
  13. DrRambone's Avatar
    Yes, using it with another carrier. I tried with my new apn, internet ok, but cannot send or receive mms.
    03-09-2015 02:53 PM
  14. Andy Belanger's Avatar
    I'm not having that problem, but now my speech to text functionality for both Cortana and messaging does not work. It's like the phone doesn't hear me at all. The little "wave graph" thing at the bottom of the screen doesn't register any sound. WTF, because it was working perfectly with PfD? No problems on a call, though...the other person hears me fine, so I know the microphone actually works. Any one else having this problem?
    03-09-2015 04:19 PM
  15. fletch33's Avatar
    i was on stock 8 and took 8.1 and have had no issues at all. no reboots, battery is amazing and even as my work phone for calls all day i end the day at 40%+ and speech to text works as expected.
    i wonder if a factory reset might fix your issue?
    03-09-2015 06:57 PM
  16. ATIV_S's Avatar
    So you were able to add a new apn for mms and it's still not working? Or does the phone automatically adds the mms apn? Thanks for the info.
    03-10-2015 08:47 AM
  17. shirlA's Avatar
    I am having the exact same problem regarding voice texting and searching - it can't hear me at all. All else is working beautifully.
    03-10-2015 10:35 AM
  18. Scottdd's Avatar
    I was running the preview version and flashed back to the original OS by following the instructions on the site and then took both OTA updates from Verizon and I am happy to say my phone is working perfectly. I have not has any lockups or any issues with the camera. I did do a complete reset, but I also did that when I loaded the preview version. I am using a surface 3, so the driver for the ATIV SE was already installed because I used the phone app on my surface. If you have not upgraded because the OTA does not automatically come through after you installed the preview version, I suggest you go through the flash process, the upgrade makes all the frustrations with the phone go away. I have no proof, but the battery life does seem better and no lock ups or reboots. Finely got the phone I thought I purchased.
    03-17-2015 10:03 PM
  19. Craig Hite's Avatar
    So far I am pleased with the update to 8.1 but I'm having a couple of minor issues... nothing terrible, but figured I'd share...
    1. A few times now, the phone has frozen and then rebooted. Has happened when using the Windows News app and also the Facebook app; the phone will freeze up completely (no response to touch, or to the hardware buttons) and then after about 20 seconds will reboot. This has happened maybe seven or eight times now, never happened before the update.
    2. A couple of times now, maybe five or six, apps will refuse to start... for example, I'll tap the Outlook app and it'll say "loading..." for a few seconds and then close. When this has happened, it seems to affect all (or at least most) apps that pull a lot of data - email, news, etc. In each case, rebooting the phone fixed it.
    3. Occasionally, voice will stop working with Cortana. I'll press the microphone icon and it'll go into listening mode, but nothing you say will register. Again, a reboot will fix.
    All of that being said, I am pleased with the update. The phone seems to run a bit faster and more smoothly now. I like the new message center, and I like the new calling functionality.
    03-23-2015 02:18 PM
  20. Craig Hite's Avatar
    Damn... maybe I spoke to soon...
    Not sure if there was an additional update or what - I haven't seen any notification about any - but over the last few weeks my experience with Windows 8.1 on this phone has been far worse...
    I've been getting random lockups and lot more frequently. At least one per day, often more, and they don't seem to follow any pattern. Sometimes when opening an app, other times when closing an app. The screen will freeze and then after a few minutes it'll reboot itself. Nothing you do in the time in between, short of pulling the battery, makes any difference.
    This morning, I woke up to find the phone frozen in that it wouldn't wake up and was completely unresponsive but with a black screen - and it was hot to the touch. I pulled the battery and put it back in, and it booted up okay and seems to be working, but it worries me how hot it was - I've had it get warm while playing a game or something like that, but nothing even close to this.
    I haven't installed anything in the past few weeks, so it anything changed it had to have happened in the background like an update. Gonna take it in to Verizon to see what they can find.
    04-22-2015 10:20 AM
  21. Jeemo's Avatar
    Go to Settings > About > More Info and post your firmware version. I suspect you are using outdated firmware
    04-22-2015 12:55 PM
  22. Gesh75's Avatar
    Wow you got it! I would also like to get one! I'm from the Netherlands too, does 4G work in our country??
    05-18-2015 05:33 PM
  23. arct1cblu3's Avatar
    Well I have the SE, I live in Mexico and Im using it with GSM, bought it unlocked and is awesome the only thing you need to do is set the APN from your data provider and thats it
    06-11-2015 09:40 PM
  24. Craig Hite's Avatar
    Nah, it turned out to be the phone. Firmware was fine. I ended up getting a replacement from Verizon (same phone) and so far it works very well :D
    09-30-2015 02:20 PM
  25. Jeemo's Avatar
    That corroborates the fact that it was a firmware issue. These phones are pretty tight (physically) and it's unlikely you had a hardware issue. From your previous description, it seems obvious that the firmware isn't handling the hardware appropriately, which is why I was asking for your firmware revision. The firmware is the software that acts as a bridge between the hardware and the developer-level software that's made to work on it.
    10-02-2015 02:09 PM
126 ... 3456
  1. Replies: 5
    Last Post: 02-27-2015, 03:21 PM
  2. Why hasn't my 1520 received the Denim update yet?
    By Chaitanya_Kshirsagar in forum Ask a Question
    Last Post: 02-26-2015, 01:10 PM
  3. What features will the surface 2 update (kinda windows 10) have?
    Last Post: 02-26-2015, 12:22 PM
  4. Readly app for Windows Phone offers unlimited access to over 800 magazines
    Last Post: 02-26-2015, 12:11 PM
  5. OneDrive Windows Phone app update revamps its photo album and more
    Last Post: 02-26-2015, 11:42 AM
