1. Rogozinski's Avatar
    Since one week I notice that my battery drains faster then before. I turned everything already off like location, synchronization and background tasks. I even did a fabric reset. My battery drains almost 20% in a hour. I am a heavy user so I am wondering if this battery is the same like the Galaxy S4 and if someone knows about a battery with more mAh?
    03-28-2015 08:54 AM
  2. Harrie-S's Avatar
    It would be helpful if you provide the battery type in your phone.
    And if you have this you could google or Bing so you could find out by yourself.
    03-28-2015 11:14 AM
  3. fletch33's Avatar
    i have bought many higher capacity batteries over the years with no problems. i do not know your exact model number but for mine THIS one which takes the standard 2000 mAh up to 2800 mAh for $16 US dollars.
    sidenote - if NFC is important to you then you might want to research a little as not all of them allow NFC to work
    xandros9 likes this.
    03-28-2015 10:57 PM
  4. Rogozinski's Avatar
    The standard is 2600 mAh... Not 2000 ;)
    03-29-2015 07:54 AM
  5. fletch33's Avatar
    oops sorry mistype but still then 200mAh more :)
    i have to say though while i am here that my battery has never died in the time i have had it. i use it for work calls all day and go to bed around 40%. over the weekend i often make it Sat morning to Sun night
    03-29-2015 03:00 PM
  6. Sean Dailey's Avatar
    The battery is interchangeable with the s4, but the back cover is not. I'm not aware of any back cover replacements for the ativ se that would accommodate an extended battery. What I did was buy an extra s4 battery and battery charger, so I pretty much always have a fully charged backup battery on hand.
    03-29-2015 05:29 PM
  7. Rogozinski's Avatar
    And what is the type of this 2800 mAh battery you have? Do you have a link? Thanks :)
    03-30-2015 08:59 AM
  8. fletch33's Avatar
    the link to the one i found is in post #3 above if you click word "HERE" and i do not have it but have had many similar to that on other phones and there are others for ATIV SE on Amazon that will go up to 2900 mAh while still fitting in original hardware. as i mentioned though i have had a few that did not include NFC capability so if that is important to you then research that.
    03-30-2015 04:29 PM
  1. Sleep Tracking continues even with low battery!
    By AndyD33 in forum Microsoft Band & Band 2
    Last Post: 03-30-2015, 03:25 PM
  2. How to have the battery replaced
    By vepac in forum Nokia Lumia Icon
    Last Post: 03-28-2015, 12:27 PM
  3. Why does my battery die quickly ?
    Last Post: 03-27-2015, 04:59 AM
  4. battery no longer charging after updates
    By rhiobhelle in forum Microsoft Lumia 535
    Last Post: 03-27-2015, 12:44 AM
