1. Erik Sg's Avatar
    Hello all,
    I will be traveling to Italy for the summer and I wondering if any of you have experience using the ATIV SE abroad. I would really like to know if anyone has experience using a European pay as you go SIM card. I don't see any reason why it wouldn't work, but I'm just trying to plan my trip so I don't have any surprises while I'm over there.
    Thanks!
    04-22-2015 01:21 PM
  2. Matthew Becker1's Avatar
    I understand the ATIV SE already comes unlocked, though you won't be able to change MMS settings.
    05-02-2015 11:11 PM
  3. xandros9's Avatar
    Yup, just make sure the band support is to your liking!
    05-02-2015 11:56 PM
  4. RoyalX's Avatar
    05-03-2015 03:13 AM
  5. Marco Budiono's Avatar
    I'm using ATIV SE in Australia. LTE works fine, internet sharing and MMS doesnt work. A couple of apps just became useless with the Verizon 8.1. For some reason I can no longer log in through the eBay app and cant send pics via Viber??
    05-07-2015 10:13 AM
  6. Erik Sg's Avatar
    Thanks for the replies everyone. I think I can live without MMS, especially if I can get a cheap data plan. Just to clarify, SMS would still work right?
    05-12-2015 07:18 PM
  7. Marco Budiono's Avatar
    yup SMS works fine. Who uses MMS anyway :)
    Erik Sg likes this.
    05-14-2015 05:53 AM
  8. Harish39's Avatar
    Hi, I am using ATIV SE in India but i am only getting 2g speeds but not 3g on data. Any idea?
    05-27-2015 11:13 AM
  9. xandros9's Avatar
    What's the service provider?
    It's highly likely the 3G bands don't line up with your provider's. (Like how in the US, phones that get 3G on AT&T won't usually get 3G on T-Mobile except in some areas.)
    05-27-2015 12:19 PM
  10. Harish39's Avatar
    I am using Airtel here and 3g bands ( 850 / 900 / 1900 / 2100 ) are supported
    05-27-2015 12:49 PM
  11. arct1cblu3's Avatar
    Im using it in Mexico (Movistar), works on H+ but here have no LTE coverage but maybe in a month will have it
    06-11-2015 08:44 PM
  1. Windows 10 Preview for Samsung ATIV S
    By Gwalk4r in forum Samsung ATIV S
    Last Post: 05-06-2015, 09:36 AM
  2. Replies: 0
    Last Post: 04-22-2015, 10:53 AM
  3. Can I use the old Xbox account (Asphalt 8 Banned)
    By Indra Krisnadi1 in forum The Xbox Lounge
    Last Post: 04-22-2015, 09:11 AM
  4. Why am I not able to use USB or Bluetooth for 510 on PC(Windows 8)?
    By Windows Central Question in forum Nokia Lumia 510
    Last Post: 04-22-2015, 12:13 AM
