The Windows 10 April 2018 update has arrived! Get the new Dell XPS 15, starting at $999.99
10-05-2016 10:16 PM
500 ... 1112131415 ...
tools
  1. Sabir Nadaf's Avatar
    As much as I would love to dual boot Android & W10 on this phone, I think it's far more complicated than it seems (dual booting launchers & android drivers etc) it is also very much off topic on this thread.
    Assuming we find that the 930 registry settings work the best, would the upgrade be possible if we follow the tutorial, make the reg changes and instead of installing windows insider, we simply install the windows upgrade advisor and wait for production builds for the 930? Are there any production builds available for the 930 through the update advisor?
    Updated to .218 update a while ago. Felt sudden change in heat. My ativ se shows less heat than before. This was the first impression though. Will let u know in time if there are any improvements in this build regarding battery and heat. One more thing. Before this update my se used to cahrge faster and drain even more faster but now charging speed has went down so i guess there is some change in battery division here.
    Hope it works well this time.
    04-13-2016 10:17 AM
  2. Pradeep Kumar Reddy Vellampati's Avatar
    I dont think that will work without sd card. Still if u want to give it a try and if 8x is not ur only device to use you can have some experimenting done with it. Sometimes things don't go straight like everyone on this forum has the same ativ se but same process was followed by everyone but still everyone faces different issues. Some don't even have issues. So do some experiment if u can. But before moving forward make sure you have stock files of 8x because if your device gets bricked you need to reflash stock files to make it work again. But if there are no files available then please do not try anything unless proven to work.
    Try to get wp8.1 developer registration and deployment tool. If you get it just try to deploy root tool app. If that app works on your cell or gets deployed to your cell then there is no need of sd card. And one more thing if ur device is with 512MB ram then don't bother going through all this. Just enjoy 8.1
    I might add this. If i were you then no matter what happens i would do something crazy to get things work. Even if i know it won't.
    Good luck buddy
    Thank you for the information Sabir. HTC 8X has 1GB RAM and 16 GB storage. I want to try this thing, but the link to download root tool is not working.
    If you happen to have the listed tools with you, kindly share the same with through OneDrive or through cloud storage. I will give a try and will update.
    Best Wishes
    Pradeep
    04-13-2016 10:43 AM
  3. Sabir Nadaf's Avatar
    Best Wishes
    Pradeep
    Ok pradeep. Tomorrow night I will upload n send u the link
    04-13-2016 11:50 AM
  4. mrspidey's Avatar
    That is good news Sabir.
    Large part of me hopes you are right and battery has been fixed, but there is also a part me that hopes you are wrong... because I don't want to do the upgrade (for the third time) just to be possibly be burned again by terrible battery usage. My issue is that my Ativ SE is my main phone - I can get away with certain w10m bugs here and there, but massive battery drain is just a deal breaker.
    Either way, keep us posted please :)
    04-13-2016 08:40 PM
  5. Sabir Nadaf's Avatar
    There are bugs though. Somethings is eating my data. My data pack extinguished for no reasons yesterday. Microsoft edge won't load certain pages. Some app don't work. But battery and heat issue seems to be fixed. Will let you know if there anything else to know.
    04-13-2016 09:28 PM
  6. Sabir Nadaf's Avatar
    After using this for a day i think you need to take the risk. Give it a try. My ativ se is my daily driver too and now i am very much happy with it. Atleast for now
    04-14-2016 09:57 AM
  7. mrspidey's Avatar
    Thanks Sabir,
    I'm seriously thinking about it but I'm not sure yet. Just so you know apparently there are known bugs for some apps not launching - if you launch them from the store, notifications area or other third party launchers they work just fine. Check here:
    PSA: Some apps may not launch in latest W10M Insider build, here's a workaround - MSPoweruser
    04-14-2016 09:49 PM
  8. Ricardo Gonzalez5's Avatar
    Thanks you for the link ... but doesn't work for my Ativ Se WP10 14295.1 :( How I rolled back all the way to 10586.218 ? somebody can tell me how ? (step-by-step) ...Thanks...
    04-15-2016 07:22 AM
  9. rmabwing5's Avatar
    Hey all you guys with battery drain issues. I have to ask, is your battery the original? I ask because my wife's ATIV SE battery just stopped charging altogether. I'm wondering if there are defective batteries in some of these phones. I know the build can effect it also but It's still a mystery to me as to why some have the issue and some don't. I purchased two aftermarket 5040 mAh batteries on ebay last night. I'm hoping this is the answer to hers being a battery thief. The other is for me... (I can't have a puny 2600 mAh battery and my wife have a massive 5040 mAh battery, right?) Anyway, I thought I'd ask. I'll let you know how it works out. Later people.
    04-15-2016 08:13 AM
  10. Sabir Nadaf's Avatar
    No way. Go back to 8.0 then to 8.1 change registry n update
    04-15-2016 11:42 AM
  11. Ricardo Gonzalez5's Avatar
    Sabir
    How I rolled back all the way to 10586.218 ? (step-by-step) ...Thanks... or win8 or 8.1
    04-15-2016 12:40 PM
  12. Sabir Nadaf's Avatar
    Sabir
    Download files mentioned in first post. Follow the procedure and you will be on 8.0 then u will receive OTA for 8.1 then sign up for developers using tool change registry and update to .218
    04-15-2016 01:22 PM
  13. Ricardo Gonzalez5's Avatar
    Thanks for the reply. I did a hard reset and it reset the phone to 14.295.100. I did not send me back to windows 8 and there was no problem. So far everything is working but hey cortana isn't in the extra settings anymore.
    04-15-2016 09:36 PM
  14. PuckCowboy's Avatar
    I'm currently on Redstone build 14291.1001 but I haven't been able to get any of the last two mobile builds for Redstone. I even tried re-imputing the registry values for the 950 (ex: "MicrosoftMDG", etc)
    I tried both Fast and Slow Ring. Just wondering if I'm doing things out of order or there are new values I need to input. I even tried the NOKIA / RM-1045 settings, but that didn't give me anything either.
    Any and all help is truly appreciated!
    Thank you in advance!
    04-16-2016 12:33 PM
  15. rmabwing5's Avatar
    That's the build I'm still on also and haven't received any updates. Not sure what the problem is there. Another thing is the fact that this build is directed towards the Lumia 950, which I have for my settings, but I found out that the 950 has a built in equalizer for audio under the "Extras" settings. This build on my SE does not have that, it still has "SoundAlive" which I believe is a Windows Mobile 8.1 setting. So, does the updates not over-write everything?
    04-16-2016 08:50 PM
  16. Ricardo Gonzalez5's Avatar
    HELP!!!
    I do hard reset because 14295 doesn't work well do not launch apps...
    I the hard reset back to me 14295 but lost cortana, then lost Store and lost windows insider, now Windows Recovery Tools 3.3.31 do not determine my device. I try to sign in on windows store and on " Choose an account" is doesn't appear any account, but my outlook work well with my email ***@live.com (microsoft account). When I try to sig in Cortana just crash, Teh Samsung Ativ Se work well sms txt, phone call, people app, wheter, news, camera ativ and microsoft, But One Drive cannot sign in just crash.
    ANY IDEA HOW TO FIX?
    Thanks a lot!
    04-18-2016 07:10 PM
  17. rmabwing5's Avatar
    Okay guys, here's my deal. I restored my phone back to 8.0, updated to 8.1.1 and proceeded with the steps to install Win 10 mobile preview on it. Problem is it doesn't matter which registry values I use it will not update to Win 10 mobile preview. It just stays on 8.1.1. Any ideas?
    UPDATE: Hold the fort, I was just making some changes to the settings, like roam and data connection, etc., and all of a sudden it came up stating there was an update and that Windows 10 is here. I'll let you know if it is the Win 10 mobile preview or not.
    UPDATE 2: OK, I finally got back to Windows 10 Mobile but it is build 10586.
    04-19-2016 08:21 PM
  18. rmabwing5's Avatar
    I just found out something; when I tried to go into Root Tool just now, the only thing that shows up is a square with an X in it. I even tried reinstalling it. I'm guessing Root Tool is no longer compatible with the version of Win10 I'm running. Any guesses?
    I'm back on build 10586 and Root Tool works again. Go Figure.
    04-19-2016 11:34 PM
  19. rmabwing5's Avatar
    Alright, it's been a day. As a side note, I changed the registry to the Lumia 950 again. I am not receiving any updates past 10586. I can't get it to update to 14291 or any other build for that matter. I know the updates are to at least 14322. What gives? I don't know why my phone just stopped getting updates past 10586. Anyone have a clue on this matter?
    04-21-2016 11:21 AM
  20. saabaa's Avatar
    If anyone has the files still from the original guide if you can get me a copy I'd be happy to update the hyperlink in the og post so it works again. I didn't realize that OneDrive link broke.
    @ Asellite -Did anyone ever get you the files from the OP? Been on XDA & stumbling thru this ad-infested site w/o success. Any pointers appreciated. :)
    04-21-2016 09:18 PM
  21. Sabir Nadaf's Avatar
    Don't download all the files together. Download those one by one. That is how it worked for me
    04-22-2016 07:32 AM
  22. rmabwing5's Avatar
    UPDATE: Okay, I just realized the latest build is 14327 as of two days ago. Still not getting new builds.
    04-22-2016 07:53 AM
  23. saabaa's Avatar
    Ok, but from where do I get the PFD_003.xap & WPSystem_006.xap files ?
    04-22-2016 01:27 PM
  24. Werentuckl's Avatar
    Rmabwing, do tell us about those new batteries you ordered for the phone. And the link to them too. 5000 mah sounds positively yummy! O_O :D
    -- W
    04-22-2016 01:51 PM
  25. AntiBillOS's Avatar
    I'm also don't able to get last Redstone builds. I also downgrase to stock and now stuck at 8.1. Any idea? Maybe Microsoft cover this backdoor and now we not able use registry hack?
    04-22-2016 06:59 PM
  1. Windows 10 Mobile build 10586
    By sanu rajan1 in forum Windows 10 Mobile Insider Preview
    Last Post: 11-20-2015, 12:40 PM
  2. Store, Outlook Mail and Calendar snag minor updates on Windows 10, Windows 10 Mobile
    Last Post: 11-19-2015, 11:39 PM
  3. How is work data sense on Windows phone 8.1 ?
    By Windows Central Question in forum Windows Phone 8.1
    Last Post: 11-12-2015, 07:01 PM
  4. Does Windows 10 Mobile have unstoppable automatic update method?
    Last Post: 11-12-2015, 02:53 PM
  5. Raspberry pi or other boards running windows 10.
    By Devilreaper in forum Ask a Question
    Last Post: 11-11-2015, 09:43 PM
