10-05-2016 10:16 PM
500 ... 17181920
tools
  1. rmabwing5's Avatar
    For those who are having problems with their charging ports, get one of these:
    https://amzn.com/B00IP8V878
    This will give you wireless charging capability without need to use the port.
    Does this actually work for the ATIV SE? Also, I believe we would need the actual base to sit the phone on too. Am I correct?
    - RW
    06-28-2016 06:06 PM
  2. Euell Gibbons's Avatar
    Yep, it works great. The SE is just a clone of the Galaxy S4, so all of the S4 stuff works with it. You will need the charging base as well, I recommend a 3-coil as they are much less futzy about position.
    06-29-2016 11:05 AM
  3. Sabir Nadaf's Avatar
    .456 update is out
    06-29-2016 05:48 PM
  4. rmabwing5's Avatar
    Thanks Euell. Which charging base do you recommend?
    - RW
    06-29-2016 06:02 PM
  5. rmabwing5's Avatar
    .456 update is out
    Cool, updating now. Will update my thread.
    - RW
    06-29-2016 06:03 PM
  6. darrell reimer's Avatar
    You're using the wrong values. RM-927 is a GLOBAL variant of the Icon, not the Verizon-specific branding of the device. Try these values and let us know the result, please:
    PhoneManufacturer to NOKIA
    PhoneManufacturerModelName to RM-927_nam_vzw_100
    PhoneModelName to "Lumia ICON"
    PhoneHardwareVariant RM-927_nam_vzw_100
    I find this very hard to believe. Try another flash of 8.0 GDR3 as described in my tutorial. Did you do this before trying?
    Thanks Jeemo. Some good news: i used the info you shared, and got this: wp_20160629_17_11_02_pro.jpg
    The bad news: when i 'check for updates', it says my phone is up to date; the update is not recognized..
    06-29-2016 07:23 PM
  7. rat_123's Avatar
    Is there any way to install ' HTC Sense TV ' app on ATIV SE to make use of the infrared port?
    06-29-2016 08:59 PM
  8. Jeemo's Avatar
    This may be a silly question, but did you checkmark the "Enable Windows 10 upgrade" box?
    06-30-2016 09:10 AM
  9. Euell Gibbons's Avatar
    - RW
    Lot's of good choices, I don't have any specific one in particular (Just make sure it is a 3-coil) . I like the stand-type ones as opposed to the lay-flat style, since you can just drop the phone in without having to line it up.
    Just find one on Amazon you like that has good reviews and you should be good to go!
    06-30-2016 11:55 AM
  10. darrell reimer's Avatar
    Yes - i clicked on the 'enable' box; i then get this:
    When i check for updates, it says that my phone is up to date.
    07-04-2016 10:23 PM
  11. Werentuckl's Avatar
    So, after a lot of hoops and crap, i finally managed to get my ATIV SE back on the W10 bandwagon from 8.1. And I immediately started missing the haptic feedback of the buttons, and the screen. Is there no way to get them back. Anyone. :'(
    -- W
    07-09-2016 04:17 PM
  12. rmabwing5's Avatar
    -- W
    W,
    Did you follow my guide to the letter? I just redid my wife's phone and have had no issues, neither with updating nor haptic feedback. I'm not sure what is going on with your phone or how you are updating it.
    - RW
    07-09-2016 04:21 PM
  13. Dieselrod1's Avatar
    OMG!! The zip file is gone I need the custom files that were in the zip file. does any one have access to these?
    07-09-2016 07:31 PM
  14. Werentuckl's Avatar
    Lets see, if RW cant get it back up, I'll upload it for you. :) He has a whole dropbox folder full of all the files we want/need.
    And yes, I did the instructions to the T, like every time. Just dont know whats acting up in all of this. Smh. I know the phone still vibrates because of vibration during the power up and the power down cycle. But I cant seem to make it do the same on the onscreen keyboard, or the return and search/cortana buttons, for the life of me. Or maybe Im just missing the right setting for it, somehow. I'm changing the haptic feedback toggle on the extras settings.
    -- W
    07-09-2016 08:27 PM
  15. rmabwing5's Avatar
    The link on this thread is dead. Go here and you will be able to get all the files needed.
    Also, go here for a line by line step to upgrade your phone.
    If you want to try out Redstone go here.
    - RW
    07-09-2016 09:39 PM
  16. rmabwing5's Avatar
    Well, I finally took the plunge and bought another ATIV SE on Ebay. I will be using it as my daily driver after upgrading it to 10586.xxx. I should have it Friday or there about. I will then be using my current one (damaged it slightly when dropped) for experimenting with Redstone.
    - RW
    07-10-2016 04:38 PM
  17. darrell reimer's Avatar
    - RW
    A wise choice rmabwing5! This phone is so under rated and awesome. Even though it's a few years old, the specs are still impressive; the size and weight is perfect; screen resolution is full 1080p HD (better than most iphones); I've got a 200 GB micro-sd in mine, and it reads it no problem. Video is amazing...i could go on:)
    07-10-2016 10:01 PM
  18. Werentuckl's Avatar
    Well, on that note. Try and see if your new ATIV works with Haptic just as well. And on that note Darrell, theres a thread trending about enabling DNG capture on some of the lower end Lumia devices, I've looked through the registries in the hopes of finding similar values or options nested somewhere on our own beloved ATIV SE but to no luck absolutely so far. Does anyone else also want to try giving this idea a shot and seeing if they can find the correct registries for the camera app if they exist, whatsoever at all. Or not?
    -- W
    07-11-2016 12:35 AM
  19. Werentuckl's Avatar
    Also, RW, brother. PICTURESSSSS :D :D :D
    Of one ATIV with the other at that too! :D ^_^
    -- W
    07-11-2016 12:36 AM
  20. westnz's Avatar
    hi. Whats the most stable build of win10 for the ativ se and easiest guide? although i am not new to romming etc this is my first windows phone.
    Thanks.
    07-12-2016 10:50 PM
  21. Werentuckl's Avatar
    Guys, .494 is out and stable to us. I just installed it and seems to be working just fine. I still dont have my haptic back though. Which sucks for just me apparently. Le sigh. :'(
    And WestNZ, the preview or production build is the daily driver version for the ATIV SE atm, and we're standing at 103586.494 as of today. :) You're easiest route onto it would be to follow RW's detailed upgrade guide over on our SE forums at his thread: http://forums.windowscentral.com/sam...-win-10-a.html
    Good luck with the progress. And the upgrade, it really takes around a couple of hours to get it all down pat if everything goes well. And you get a brand new spanking WM10 phone out of it too. :)
    -- W
    07-12-2016 11:52 PM
  22. electricgary's Avatar
    I just updated my Samsung Ativ SE to windows 10. I am on build 10586.107 and I think it runs really good. I wish haptic feedback worked but that is the only thing I found not working. Thank you for the guide. I am unsure if I want to proceed further since this is my daily driver right now. I do have a Lumia Icon and I had an issue with the sim card but before I found out it was the sim card I bought the Ativ SE. So I figure for $75 I will use this phone and leave the Icon tucked away for a later day.
    07-15-2016 12:24 PM
  23. Werentuckl's Avatar
    Well, ElectricGary, you're the second person besides myself who is also having the haptic feedback issues - so I'm guessing with more people cropping up with the problem, we'll be able to get/identify some sort of a solution to this somewhat/seemingly isolated problem.
    And in answer to your question, you definitely want to upgrade it to .494 atleast because that is stable, and works much better than the .107 ever did, in terms of both stability and battery life. Most people on this thread here are on it, and their phones are their daily, or somewhat daily drivers, for that matter. So yes, go ahead and make the jump, and tell us how it works out.
    On that note though, secret question, how much would you be willing to part with the Icon for? :P ;) :D
    Joke, not joke. :P
    -- W
    07-15-2016 11:15 PM
  24. darrell reimer's Avatar
    Joke, not joke. :P
    -- W
    Trying this build:
    07-15-2016 11:54 PM
  25. Werentuckl's Avatar
    Woahhh, Darrell! You're getting really adventurous there friend. You know we wont have hard reset on Redstone until it goes RTM right. You just had to wait a couple more weeks bro. :P
    -- W
    07-16-2016 12:00 AM
500 ... 17181920
  1. Windows 10 Mobile build 10586
    By sanu rajan1 in forum Windows 10 Mobile Insider Preview
    Last Post: 11-20-2015, 12:40 PM
  2. Store, Outlook Mail and Calendar snag minor updates on Windows 10, Windows 10 Mobile
    Last Post: 11-19-2015, 11:39 PM
  3. How is work data sense on Windows phone 8.1 ?
    By Windows Central Question in forum Windows Phone 8.1
    Last Post: 11-12-2015, 07:01 PM
  4. Does Windows 10 Mobile have unstoppable automatic update method?
    Last Post: 11-12-2015, 02:53 PM
  5. Raspberry pi or other boards running windows 10.
    By Devilreaper in forum Ask a Question
    Last Post: 11-11-2015, 09:43 PM
