09-26-2016 11:38 AM
33 12
tools
  1. Werentuckl's Avatar
    It works as per the settings for the 930, the 1520, and even the 950. The OS versions pushed out for those do talk to the ATIV SE. But like you said, they do niggle and they do wiggle, a little. And some people do great, and others not so great. So all in all, a great question of YMMV. :)
    -- W
    ven07 and xandros9 like this.
    04-26-2016 11:06 AM
  2. darrell reimer's Avatar
    Agreed and adding this.. With the hack you will only make it to build 14295. The RS builds aren't going to be an option for you. All non-supported phones (those that aren't getting w10m officially) go into a bootloop when trying to update to the last two 143xx builds.
    If you want to "use the fake ID" trick, you could get to build 218, which is working fine :)
    My phone is running awesome! No problems at all; great phone! Like it much better than my Lumia 830...
    ven07 likes this.
    04-30-2016 01:54 AM
  3. Brad Herr's Avatar
    Just thought I'd chime in here and mention that new Insider Fast releases seem to be working again. I have my Ativ SE on 14342.1001 using the registry hack trick. Phone is constantly hot, and battery life is atrocious, so I can't recommend, but it's just my backup phone at this point anyway, so it's nice for me to be able to continue checking out the new builds while I wait for something great to come out.
    Werentuckl likes this.
    05-17-2016 09:42 AM
  4. PuckCowboy's Avatar
    Hey Brad, may I ask what your exact settings are?
    I'm using MicrosoftMDG / RM-1104_1078 on my backup ATIV SE also, and I'm still stuck on 14291.1001. I tried Fast Ring, but it keeps showing phone is up to date.
    If you could provide more info, or a mini-guide on the settings you used for Root Tool, it would be truly appreciated.
    Thank you in advance!
    05-22-2016 04:25 PM
  5. darrell reimer's Avatar
    Once you get to W10M... Your updates to the OS will come as WaaS updates. Windows as a Service will push OTA to any capable device. Carriers and OEMs are still responsible for Firmware and neither Ativ nor One (M8) would be expecting any new Firmware at this point. But WaaS will deliver your OS features, bug fixes and patches at the same time as any other model. With the limit being only those updates to Threshold would apply. No upgrade to Redstone builds would be possible.
    Now working with this; runs solid; battery life is ok. Not hot. wp_ss_20160602_0001.jpg
    05-28-2016 08:23 PM
  6. nate0's Avatar
    If Ativ SE is the best price I say it is a great value and since it is in WDRT you could reset to 8.1...
    When did that become available? Since I've owned my Ativ SE I've never been able to reset it via wdrt.
    RumoredNow likes this.
    09-26-2016 11:06 AM
  7. RumoredNow's Avatar
    You know... It looks like I made a blunder there. I simply can't find anything to support my statement. I must have mistaken SE with something else added to WDRT around that time.
    I've edited the post you quoted to remove the incorrect information.
    Thanks..
    09-26-2016 11:17 AM
  8. nate0's Avatar
    Thanks..
    No problem. Would've been nice for it to have been though...
    09-26-2016 11:38 AM
33 12
  1. Is windows mobile really dying?
    By Felipeicd in forum General Phone Discussion
    Last Post: 05-10-2016, 03:51 PM
  2. Skype back to stand-alone app, at last. Standing by new UWP
    By Maurizio Troso in forum Windows 10 Mobile Insider Preview
    Last Post: 04-25-2016, 04:13 AM
  3. Anyone know how to edit registry to pretend to be a Lumia?
    By hughjazz44 in forum Ask a Question
    Last Post: 04-23-2016, 02:20 PM
