12-06-2016 06:22 PM
65 123
tools
  1. PuckCowboy's Avatar
    Hey all. Just curious if anyone plans on jumping to the Windows 10 Anniversary Update on August 9th. Per WindowsCentral, that is when it will be available to all open phones. Im guessing we will need to tweak registry to be on the Redstone build (Nokia 950 settings) to get it in insider preview, correct?
    Im still on Threshold since Redstone was too finicky on my backup ATIV SE. Id be interested to hear how the Anniversary edition performs.
    Thanks in advance!
    08-07-2016 12:00 PM
  2. Werentuckl's Avatar
    Redstone seems to be working pretty decently as of the .5 update on the ATIV SE. And the values you have here are just fine, you just need to make sure you use the phone model RM 929 in your registry values while upgrading. The update shows on RP with those values too since the build is on RP now. :)
    -- W
    08-07-2016 12:25 PM
  3. darrell reimer's Avatar
    Thanks in advance!
    I just got this update via Release Preview:
    Jeemo likes this.
    08-10-2016 01:34 AM
  4. Dieselrod1's Avatar
    How can I tell the difference between a regular preview release and the Redstone release? I am now at 14393.67.
    08-11-2016 07:58 PM
  5. Jeemo's Avatar
    That's Redstone. 1511 is TH2, 1607 is RS1
    08-11-2016 08:09 PM
  6. darrell reimer's Avatar
    Looks like we're out of luck with the Preview For Developers app. It was apparently pulled from all phones not on the list to get the Anniversary Update.
    Preview for Developers is still in the Windows 8 store; I just restarted from scratch the entire upgrade process on one of my other Ativ SE phones (because my Store was a mess after the latest 1607 14393.67 update), and when my phone was finished updating to 8.1, P for D was in the store!
    08-15-2016 12:25 AM
  7. westnz's Avatar
    14393.82 is available downloading it now
    08-16-2016 10:07 PM
  8. danslb's Avatar
    Im tempted to get an Ativ SE and do the registry hack and use it in the EU.
    1. Does anyone have experience in doing this and using an SE in the EU? Does SMS and 4G work for you?
    2. Once the reg edit and update to Win10M are complete, is your device getting regular (production) updates such as TH2 and RS1, or do you have to keep flashing ROMs to get it up to date?
    08-17-2016 06:08 AM
  9. Werentuckl's Avatar
    You can see the LTE bands that work in your area and telly them with the ones on the device. Other than that, everything else works like a charm. SMS, data, 3G. :) And once you do the registry edits and get to WM10, you are good to go. As long as the device you're spoofing keeps getting the updates. So do you. My Ativ SE is my daily driver. And I have no complaints so far. :)
    -- W
    danslb likes this.
    08-17-2016 06:50 AM
  10. danslb's Avatar
    Loved the Ativ S, so much that I actually replaced the broken glass myself. My 70 year old father now has it and loves it. I have had the 1520 for about 1.5 yrs now and often think back to how nice the Ativ S was. A real shame they never released the SE worldwide. Not able to resist the temptation I just ordered one off ebay and will probably spoof it to a Lumia 930. Any better suggestions? Would it be a better idea to put it on the Icon because of radio or band issues?
    08-17-2016 08:15 AM
  11. Jeemo's Avatar
    The Lumia Icon has nearly identical hardware to the Ativ SE; all Qualcomm components (processor AND connectivity radios) are the same for both devices. However, they have been configured differently to support different bands. Once we get the SecureBoot exploit for mobile devices, it'd technically be possible to unlock radio bands that are available on any phone that uses the MSM8974. Whether or not the SE or Icon work for your network depends on the bands that your network uses. If you want to see a side-by-side comparison, here's the link:
    Samsung ATIV SE vs Nokia Lumia 930 - Phone specs comparison
    If you scroll down to the Cellular section you can see the frequencies which have been enabled, and compare those to your carrier. I know there are a few dedicated users of the SE in Russia and Poland (check out the forums on 4pda.ru and windowsmania.pl), but I haven't seen any statements about whether or not it works with all of the bands on their network. Things like MMS APN can be changed through the registry, so don't worry about MMS as long as your carrier's bands are supported. Best of luck
    08-17-2016 01:21 PM
  12. danslb's Avatar
    Thanks for that Jeemo,
    What are the chances of SecureBoot becoming available and what is the story behind that?
    08-17-2016 02:01 PM
  13. Werentuckl's Avatar
    And yes, as Jeemo said. The Icon would be your better be out of these few options. Just saying. Since he has already explained it so well so far already. :) ^_^
    -- W
    08-17-2016 02:06 PM
  14. Jeemo's Avatar
    Highly likely. The RoL team has already released the exploit for Windows RT devices, and have publicly stated that the mobile version is being worked on and that they're planning on a release soon (there was no specification of how soon). In order to implement the exploit, we need to have the ability to access an elevated CMD prompt on the device. Snickler at XDA has gotten that working, and Gustave (@gus33000 on twitter) is integrating it into Interop Tools (check twitter for progress). I'm unsure about whether or not the implementation of CMD access will work with our device, but if it does, we're all set for bypassing SecureBoot. If it doesn't, I've talked to a few people involved and they will work with me and a couple others with the device to make necessary changes.
    I'm also going to comment on the physical factors between the SE and the Icon, as I currently have them right next to each other in front of me. I've gotten very used to the SE over the last year and a half, and I think it is incredibly comfortable. The SE is lighter than the Icon, and the form of the SE fits much more comfortably in my hand. The Icon looks better, and it feels like a more refined product when it is in your hand. The screen and glass quality on the Icon is superior to the SE. In terms of performance, they seem to be identical. The SE has a significantly better speaker on the back. The Icon has significantly better recording, in terms of photos, videos, and audio. Neither of them are perfect, but they're both ******* awesome. I honestly believe that my past 2 months on RS1 on the SE have been the best Win10m experience available, on any device (and yes, I've tried the 950), however I had to make various changes that go beyond the scope of this tutorial to get to that stage. As long as they support your carrier's bands, you will be happy with either device. The Icon has more publicly available research, and most user-friendly tools for tweaking are made for Lumia, not Samsung. The Icon will be the easiest route to Win10m, but you could get there on the SE if you're willing to put in the time.
    08-17-2016 04:07 PM
  15. danslb's Avatar
    thanks again Jeemo. I'm picking up a 930 in the mail tomorrow, that should supposedly get W10M RS1 as MS promised and no tweaks needed. The SE I plan to mess around with following your tutorial and get it up to date as well. I noticed supported bands are not the same on Icon and 930. The SE has the band setup for the US like the Icon, but I suppose the 930 has the same radio just a different config. hence spoofing the SE to Icon makes more sense, avoiding any mismatch with the radio bands.
    08-17-2016 04:40 PM
  16. Jeemo's Avatar
    Yup, exactly! All three have the same stack from Qualcomm; the carrier-specific versions are just configured differently. Just a heads up, my tutorial is no longer functionally (I believe). I will be making a new tutorial within the next week or two. If you want to update immediately, a new tutorial has been posted within the last few pages of the stickied tutorial thread. I'd send the link but I'm writing from mobile
    08-17-2016 05:10 PM
  17. danslb's Avatar
    Thanks bit waiting is my only choice now. I should be getting the SE in a couple of weeks.
    Jeemo likes this.
    08-17-2016 05:14 PM
  18. Jeemo's Avatar
    Well, hopefully I'll have things finalized then
    08-17-2016 10:12 PM
  19. westnz's Avatar
    That would be great cause we have bands 3,7,28 in NZ no 4 or 13
    08-18-2016 04:19 AM
  20. Werentuckl's Avatar
    Sadly, I only have band three here too. At the 1800 MHz spectrum. :(
    -- W
    08-18-2016 06:39 AM
  21. westnz's Avatar
    14905.1000 on the fast ring downloading now
    08-18-2016 03:27 PM
  22. Werentuckl's Avatar
    Woaaahhhh!!! West. You sure you want to be that cutting edge brother? And also, Jeemo. Take your time mate. As long as that Icon dont steal you away from us that is! >_< :@
    -- W
    Jeemo likes this.
    08-18-2016 03:55 PM
  23. westnz's Avatar
    -- W
    ive always ran betas n alphas as my main os ever since my win2000 beta in dec '98. ive been doing it for so long i cant help it heh
    08-18-2016 05:05 PM
  24. Werentuckl's Avatar
    Oh. Damn. You ran the original Windows 2000 Beta. And I'm guessing the ME Beta too. You have my respect for that ME and that 2000 bro. Respect. O_O
    -- W
    08-18-2016 05:13 PM
  25. westnz's Avatar
    -- W
    man i still remember what a dog of an os that win2000 beta was ran so slow i thought damn will i have to upgrade my pentium pro but at the finish it was much faster.
    08-18-2016 05:46 PM
65 123
  1. continuum monitor app on android(or iOS)?
    By rory753 in forum Continuum
    Last Post: 06-10-2016, 09:41 AM
  2. Replies: 1
    Last Post: 06-09-2016, 08:38 PM
  3. Where did my Outlook contact go to?
    Last Post: 06-09-2016, 08:00 PM
  4. This Week in HoloLens: HoloTube, HoloBlocks, and a new helper app
    Last Post: 06-09-2016, 04:11 PM
  5. Free Minecraft Battle update coming to Xbox One on June 21
    Last Post: 06-09-2016, 04:00 PM
