05-02-2018 12:20 AM
423 ... 34567 ...
tools
  1. Jeemo's Avatar
    OK Cool yeah I'll do that. Another thing the stock camera app seems to be working ok if flash is off. If you take one with flash on you need to reboot the phone because it becomes all screwy. In the 494 build you could use the ativ camera to reset the camera if I remember correctly, this build requires a full reboot.
    Ativ Camera can take shots with flash on ok.
    I can confirm the flash issue; I've been struggling with that for the last 2 weeks (before 14393 even). Unfortunately the issue isn't exclusive to flash, and sometimes I can even get multiple flash shots working properly. I don't think this issue is specific to our phone, however, so I expect it to be fixed in the coming updates.
    Also, just giving you a heads up to read my above post since I didn't quote you in it. Congratulations again
    08-08-2016 03:59 PM
  2. Werentuckl's Avatar
    Jeemo, could you kindly give RW's updated files a go as well when you do so that we can be sure if our older method - on all four threads - has really been deprecated or do we have two alternate pathways onto the WM10 train now. It just struck me that if it has really been deprecated, it would make the earliest two WM10 threads on the subforum obsolete, and one of them is stickied. So it would be best to only have the more concise and updated two tutorials up here, and on the stickies.
    -- W
    08-08-2016 05:50 PM
  3. westnz's Avatar
    no problem its a good feeling to help and be back in win10. yeah I read all the posts I kept refreshing every half hour tbh after I posted my solution I was real excited to post my steps
    Werentuckl likes this.
    08-08-2016 07:20 PM
  4. BATTAT's Avatar
    I'm having trouble following your steps for I get the 8.1 update to get to windows 10 but after that it doesn't update to windows 10 am I missing something?
    08-08-2016 08:44 PM
  5. rmabwing5's Avatar
    @Werentuckl haha you're right, I didn't notice he was on NZ!
    @rmabwing5 you can't sideload PfD without an interop unlocked phone because of the capabilities it has.
    @westnz ******* AWESOME job man!! I'm glad you were able to get your hands on the files and that you were able to successfully use that tutorial! Great job making new instructions in english, as well. Rmabwing5 and I should update our tutorials soon. However, I will be waiting to update mine until Anniversary Update goes out and I can confirm the final process myself (which I will now be doing right away, since you confirmed that this is still possible). HUUUUUUGE thank you for confirming it! I had a good feeling that it would work, but I wasn't confident enough to risk losing win 10 on my daily driver. I really appreciate your efforts, and I'm sure others do too. I'll be sure to credit you in my updated tutorial when the update goes live within the next few days.
    True, Jeemo, I didn't think of that (side loading PfD). You are correct, can't be done. PM me so we can get our ducks in a row on how to resolve this issue before I change my thread instructions.
    Thanks in advance
    - RW
    08-08-2016 09:05 PM
  6. westnz's Avatar
    1 other thing I just did an about reset not a hard reset. What is the difference between those 2 btw anyway?
    08-08-2016 09:21 PM
  7. BATTAT's Avatar
    Is this step necessary from the OP?
    Open Root Tool from your apps list on your phone
    i. Select "For All Windows Device"
    ii. Select HKEY_LOCAL_MACHINE radio button
    iii. Under "Registry Path to Operate" type System\Platform\DeviceTargetingInfo
    iv. Under "Registry Key" type PhoneModelName
    v. Under "Registry Value" type RM-929
    vi. Click Write
    08-08-2016 09:37 PM
  8. darrell reimer's Avatar
    I discovered something. I side loaded Interop Tools, which is a non-app registry editor add on, which resides under Extras. I then went into the registry and discovered that haptic feedback is indeed there but called Vibrate under HKEY_LOCAL_MACHINE\System\Touch\Buttons\Vibrate. When I select Vibrate, it states a DWORD value of 1, which of course means ON. But, our devices continually result in no vibration or haptic feedback. I tried entering a new key called HapticFeedbackSupported, which I found on a Microsoft support page, not in a forum, but I get an Access Denied error. I guess even though we can unlock the OS and hack the registry for phone updates we can't change something as mundane as getting haptic feedback to work. Some other sites state we can do this but they are older and my guess is Microsoft killed the editing ability for certain keys in the registry. By the way, I tried this on my test ATIV SE which is running the latest Redstone version. By the way (2), on this phone I still have problems with the bottom touch keys not working from time to time. Rebooting helps, which by the way I have to remove the battery to do so because it will not reboot normally.
    Anyone else having any ideas about the haptic feedback, would be really appreciated.
    - RW
    Some of my vibration settings work: I have my phone set to vibrate when an outgoing phone call is answered, and it works.
    08-09-2016 12:00 AM
  9. Werentuckl's Avatar
    Vibration works Darrell, its just the haptic feedback on the buttons that doesnt. Sadly. :(
    -- W
    08-09-2016 01:10 AM
  10. darrell reimer's Avatar
    I may just have gotten the phone onto the RS path track over the Release Preview Ring.
    Could someone verify this for me. I kind of forgot what Release Ring I was in because I enrolled quiet a few times in different rings in the hopes my settings would let the phone see the RS update on some ring atleast to no luck. At all. Until I changed the PhoneModelName to Lumia 929. At which point, viola! It saw the updates. And now I have no way of checking, or know of any way atleast, if I did this while on the RP on the insiders. So can someone verify this for me, if these registry changes get us to RS on Release Preview or not?
    Thanks. :)
    Edit: Here is the complete set of values for the RS update over Release Ring, if anyone can verify it for us.
    PhoneManufacturer: NOKIA
    PhoneManufacturerModelName: RM-927
    PhoneModelName: Lumia 929
    PhoneHardwareVariant: RM-927
    -- W
    Yes!!! It works:) I'm downloading 14393.5 using the Preview Release setting!
    08-09-2016 02:10 AM
  11. Jeemo's Avatar
    @westnz there's no difference between the two as far as I know.
    @wer Yea, When I have time to I'll be keeping my sim card in my other device for a week and testing all of our methods so that we can clean up the tutorials. Unfortunately it's possible that we will lose access to TH2, unless there's another msm8974 device that got an official update to TH2 but is being left out of RS1; which is very possible, so keep your hopes up if you prefer TH2.
    @RW When I start doing more testing (it won't be until this weekend most likely), you'll be the first person to know. Let me know if you get any more info as well. I assume you'll be trying different methods since you have a spare SE?
    08-09-2016 04:14 AM
  12. rmabwing5's Avatar
    Jeemo, Yes, I'm back on 8.1 on my test phone. I'm going to try a few things and see what happens. Will let everyone know how it goes once I have some concrete results.
    - RW
    Jeemo likes this.
    08-09-2016 06:37 AM
  13. westnz's Avatar
    I'm 3/4 an hour away from the 10th August here in NZ n no builds fast or DP higher than 14393.5...
    08-09-2016 07:15 AM
  14. Pieluna Anais's Avatar
    factory resetted 8.1
    connected to wifi but turned off auto update apps in initial setup
    unlocked via developer phone registration
    Original Thread by westnz
    Requirements : ATIV SE running latest WP8.1.1 (Update 1) Build and following files
    https://mega.nz/#!CMVziZIL!w1fdfgb2m...Wyl1AhfYceS9w8
    https://mega.nz/#!2RVlwJKR!LR0JL_b0M...FqbO3wPd21RbW8
    1. Factory reset your phone. ( if needed )
    2. Do setup. Connect to Wi-Fi, select custom, uncheck auto update apps.
    3. Unlock your phone via Windows Phone 8.1 Developer phone registraiton.
    4. Go Settings, date+time, set date 100 years forward. ( no reboot needed )
    5. Go back to Settings, scroll down and click call/message settings.
    6. An error popup occurs. Proceed uninstall.
    7. Then set date+time back correctly.
    8. Copy InteropUnlocker_SE_81.xap & wphTweaks_v10.xap into the root of SD card.
    9. Create a blank txt file and rename it Non-Production Errors.txt
    10. Copy the txt file you just created to Documents folder in the phones memory.
    11. Using SDK, deploy SamWPSystem to phone memory.
    12. Go Storage Sense, change where to store new apps to SD card.
    13. On app list, open CustomWPSystem.
    14. Click SD Card permissions box, tick sd card and press OK icon.
    15. Click Unhide WPSystem too. Two of items will be green then.
    16. Select AdditionalCallSettings as the target app and press Download from Store.
    17. After install it again, go back to CustomWPSystem.
    18. Select the XAP > sd card > InteropUnlock_SE_81.xap and go apply XAP.
    19. Open Settings, scroll down to the bottom, run additional call settings.
    20. Hit Unlock. When it succeed, reboot the device.
    21. With SDK, deploy wphTweaks.xap
    22. Open WPH Tweaks > tools > tap registry editor.
    23. Follow OP's guide by step 16.
    ( You can browse the item with double click )
    Well... did I follow right steps?
    westnz and Jeemo like this.
    08-09-2016 07:43 AM
  15. Pieluna Anais's Avatar
    Had the registry hacks I enrolled the Release Preview build.
    But it only takes me to 8.10.14219.341 - No more updates found.
    Once it done windows insider makes an error when trying to change another release.
    ' Sorry, we cannot configure your device because it is currently preparing an update. Please install the update ( Settings > Phone Update ) and then try again )
    OMG... I hope I did something wrong. Going to start over.
    08-09-2016 07:54 AM
  16. westnz's Avatar
    Your layout is more clear.....I was in a rush in my post excited to get word out it can be done :)
    ....although I did not use the sdk app deploy in step 21, I used that one in the mega link I got from another place because I was having trouble with the sdk one a day or 2 earlier . I believe it is a hacked one. But, that is not to say the sdk one doesn't work because I never tested the sdk one in this process.
    08-09-2016 07:56 AM
  17. westnz's Avatar
    that is an error when it needs to continue with a minor/another update before it starts the win 10 update I believe
    08-09-2016 08:04 AM
  18. Pieluna Anais's Avatar
    Several times of hard reset and starting over from WP 8.0 didn't worked. It wouldn't let me get insider release preview build.
    I set registey hacks exactly same with OP - NOKIA RM-927 Lumia ICON. This settings took me up to DENIM build that installed before WP10.
    So I made some changes. Just change PhoneModelName to RM-929 and enrolled Insider Fast. And, it worked.
    Well... let me have a check what happens.
    08-09-2016 03:03 PM
  19. Euell Gibbons's Avatar
    Just want to let everyone know that I was able to update to the very latest (14393.67) build easily. Once you have the first Win10 (10586.107) installed, just re-select the Release Preview ring and go to town. Mine went straight from .107 to 14393.5, and then I got today's update. Pretty sweet!
    westnz and darrell reimer like this.
    08-09-2016 06:48 PM
  20. westnz's Avatar
    yep im on 14393.67 now too
    08-09-2016 09:08 PM
  21. Pieluna Anais's Avatar
    Me either got the update directly to 14393.67 with Fast ring.
    WP 8.1.2 DENIM final build > WP 10 10586.107 > 14393.67
    BTW do you think that interop unlock method is still available on WIN10?
    08-09-2016 09:22 PM
  22. darrell reimer's Avatar
    -- W
    I just got this update; maybe it will work...
    08-10-2016 02:30 AM
  23. westnz's Avatar
    tbh I dont know. what happened was i was following the 8.1 interop unlock guide thru but I couldnt change a key so I thought stuff this and gave up on permanent interop unlock then I crossed my fingers I could change the samsung to nokia keys to update to win 10 and it worked then posted my rough guide :)
    08-10-2016 05:16 AM
  24. Pieluna Anais's Avatar
    Anyone, if you face troubles downloading keyboard text suggestions update for additional language, just switch insider build to fast ring. You can switch to your favorite anytime you want.
    08-10-2016 12:41 PM
  25. Jeemo's Avatar
    Quick thing I want to discuss.
    An exploit for the Redstone SecureBoot stack has surfaced, and supposedly allows TestSigning to the bootmgr (previously we only had TestSigning post-boot). This means that we could possibly run self-signed EFI's, and therefore custom ROMs. This is currently applicable to all devices running Redstone (although not yet confirmed on Xbox One). As our phone is running Redstone with SecureBoot, this potentially applies to us. The exploit is very difficult for Microsoft to patch, because in doing so, they would ruin bootchain-passability (I made that up) for various legacy devices (for example, the most logical patch would make it impossible to boot into the recovery partition on a PC, or the flashing interface on a mobile device). It is likely that Microsoft will only be able to patch this exploit for devices that have been manufactured post-Redstone.
    TL;DR:
    There is a strong potential for being able to run custom ROMs on the Ativ SE in the near future.
    08-10-2016 07:43 PM
423 ... 34567 ...
  1. Replies: 2
    Last Post: 06-25-2016, 08:38 AM
  2. How can I use an .exe program with Win 10 Mobile?
    By Extea in forum Windows 10 Mobile
    Last Post: 06-13-2016, 02:04 PM
  3. Titanfall 2 single-player campaign revealed in jaw-dropping new trailer
    Last Post: 06-12-2016, 03:11 PM
  4. Follow Windows Central for all the best from E3 2016!
    Last Post: 06-12-2016, 01:42 PM
  5. not able to connet Wi-Fi in lumia 920
    Last Post: 06-12-2016, 01:22 PM
