1. Markus Kink's Avatar
    I'm sorry , it's a Samsung ATIV SE 16gb Verizon
    operating system is windows 8
    my sim card works perfectly in Germany , but every time I turn off the phone , the date and time no longer is the right ohne ( 07.20.2013 / 4 : 20 ) there are many Apps they don't work fine.
    How do I get Windows 8.1 ? have no idea how that is ? I find myself in Germany😟😟😟😟😟
    The Phone tels me it is the right Version
    07-19-2016 12:44 PM
  2. Chintan Gohel's Avatar
    go to settings > update > check for updates - but I'm not sure if 8.1 is available for your device
    You could also do a factory reset so the issues are removed
    07-20-2016 03:06 AM
  3. Markus Kink's Avatar
    Thank you but the factory reset doesn't works.
    I have a chance to run to get windows 8.1 without Verizone ?
    07-20-2016 09:06 AM
  4. Jeemo's Avatar
    If you could Developer Unlock the device, there are 8.0 registry editors that you could use to make it seem like it was a Verizon device, therefore enabling the upgrade to 8.1. Unfortunately, now that 8.0 Developer Registration has been terminated (specifically because of this vulnerability, presumably), I'm unaware of any way to sideload an XAP to an Ativ SE that's running 8.0.
    Chintan Gohel likes this.
    07-20-2016 09:44 PM
  1. How can I fix a Lumia 950 Photo problem?
    By Shandybang in forum Microsoft Lumia 950
    Last Post: 10-06-2016, 01:58 AM
  2. Samsung's Notebook 7 spin is now available in the U.S.
    Last Post: 07-19-2016, 01:50 AM
  3. Why cant my samsung android 4 connect to my laptop
    Last Post: 07-18-2016, 05:26 AM
  4. Glance Screen Problem In Lumia 640 xl, how can I fix this?
    By thisara98 in forum Microsoft Lumia 640 XL
    Last Post: 07-17-2016, 10:02 AM
  5. Lumai 1520 Reboot Cycle, Wifi Problems
    By silvertonesx24 in forum Nokia Lumia 1520
    Last Post: 07-17-2016, 04:38 AM
