The Windows 10 April 2018 update has arrived! Get the new Dell XPS 15, starting at $999.99
  1. darrell reimer's Avatar
    Does anyone know how to enable AWS bands 1700 or 2400 on our Ativ SE phones? Is there a way to do this through a registry editor? Did Verizon 'hide' this (like the MMS settings). I've switched from Telus to Wind/Freedom mobility; I can't seem to get this phone to find their AWS 'home' network; it always wants to roam....; I've got 2 Ativ SE's; one running 8.1, the other Win 10.
    I bought a Lumia 650 from the Microsoft store (because it was half price on sale - $99 CAD), and it works perfectly on Wind/Freedom. Great little phone for the price, but...the Ativ SE is still a much better phone; I can't let it go! I just can't get it to work on the Wind/Freedom network, even though when I type the IMEI number into their 'compatibility' search engine, and it says that my phones should work (it shows our phones as 'Galaxy' family phones). I found a video of some guy enabling AWS on a Samsung Note 2,and the inside of the phone looks just like our Ativ SE, but it's running Android; Any ideas?
    12-17-2016 10:17 PM
  2. libra89's Avatar
    You need access to field test which only works with a sim inside said phone. Field Test works with Lumias, but not sure about this phone. Try typing #3282## and tap call to see if that works.
    12-17-2016 11:17 PM
  3. darrell reimer's Avatar
    Thanks for your suggestion; I tried this, but I get an error message: 'something happened; couldn't complete this action'....
    Update: after digging around, I found that ## 33284 gets me in, but then I get stuck; I try all kinds of different codes, but nothing works; i'll keep trying....
    12-18-2016 12:38 AM
  4. libra89's Avatar
    Oh no, that means that it isn't supported probably. :(
    12-18-2016 12:41 AM
  5. fatclue_98's Avatar
    AWS is Band 4 which the SE already supports. I've used this phone on T-Mobile many times. You don't need to do anything.
    libra89 likes this.
    12-20-2016 01:29 PM
  6. darrell reimer's Avatar
    I need AWS frequency 1700 or 2400 (which I don't see on the Ativ SE specs sheet....) I'm trying to get this phone working on the Freedom/Wind network in Canada...
    Ativ specs:
    CDMA:
    800, 1900 MHz
    GSM:
    850, 900, 1800, 1900 MHz
    UMTS:
    850, 900, 1900, 2100 MHz
    LTE (FDD):
    Bands 13, 4
    12-21-2016 07:56 PM
  7. fatclue_98's Avatar
    Ativ specs:
    CDMA:
    800, 1900 MHz
    GSM:
    UMTS:
    LTE (FDD):
    Bands 13, 4
    LTE Band 4 is AWS (formerly 1700/2100)
    libra89 likes this.
    12-21-2016 09:17 PM
  8. darrell reimer's Avatar
    Thanks for the info; then i'm wondering why it won't work with the Freedom/Wind frequencies? It does not pick them up when I do a network scan. I just bought an Lumia 650, unlocked from the Microsoft store; great little phone, and it works perfectly with Freedom's network. For some reason, I can't get either of my Ativ SE's to work (one is running 8.1, the other Win 10). Both do not 'see' Freedom's signal (they just see Bell, Rogers, and Telus). Freedom does not have LTE (only 4G). Would that be the difference?
    12-21-2016 11:36 PM
  9. fatclue_98's Avatar
    If your carrier doesn't have LTE you're not going to get LTE speed. You're only going to get HSPA if their UMTS bands are supported.
    Sent from Alcatel Idol 4S with Windows via mTalk
    libra89 likes this.
    12-22-2016 07:55 AM
  10. darrell reimer's Avatar
    I've got a registry editor. Do you know the path to changing the radio frequency? Can this be changed, or is it 'fixed' into the hardware of the phone?
    12-22-2016 07:29 PM
  11. fatclue_98's Avatar
    Nah, that's built into the silicon.
    libra89 likes this.
    12-22-2016 08:06 PM
  12. darrell reimer's Avatar
    Oh no!!! I've been searching through all of the different hives and registry values trying to find something to change the frequency....Ahhhhhhh...this is such a great phone. What a shame I can't use it anymore!
    12-22-2016 11:52 PM
  13. Euell Gibbons's Avatar
    Look at http://www.frequencycheck.com/ to see if a phone will be compatible with a specific carrier. It is an invaluable resource.
    darrell reimer likes this.
    01-06-2017 12:24 PM
  14. darrell reimer's Avatar
    Thanks Euell.
    UMTS
    Compatibility - 0 out of 1 band supported
    0%
    Interface Name Supported by device?
    UMTS B4 (1700/2100 AWS 1) No
    01-15-2017 08:04 PM
  1. I got visual voice mail working on my unlocked 950xl
    By newEDB in forum Microsoft Lumia 950 XL
    Last Post: 01-04-2017, 10:08 AM
  2. Freeze and Random Reboot when Low on Battery
    By AnubisJack in forum Microsoft Lumia 950 XL
    Last Post: 01-01-2017, 08:37 AM
  3. Possible virus on Windows phone
    By Carlggg in forum General Phone Discussion
    Last Post: 12-17-2016, 05:06 PM
  4. why cant i hear the ringtones on my phone even though sound is turned up
    Last Post: 12-17-2016, 05:02 PM
  5. How to remove 'Windows Insider Program' from Settings on Windows 10
    Last Post: 12-17-2016, 02:11 PM
