1. Erik Sg's Avatar
    Hi guys. I've been having some issues with my ATIV SE after upgrading to W10 mobile and I was hoping that I could do a reset and start over from scratch. Mostly the issues are with built in apps like Weather and News not launching, and slow performance in general. Is resetting the phone as simple as pressing the button combination to wipe it, or will that mess things up since I've installed W10 mobile onto it? Is there anything else I should be aware of before doing this?
    02-09-2017 07:15 PM
  2. David Jewers's Avatar
    You can reset and fix issues but you will be stuck on the build you are currently on (you would have to go back to 8.0 and re-interop unlock etc to go back to WM10). If you aren't using Verizon then it will screw up any changes you've made to the APN and 3g. If you're on Verizon you're golden.
    03-08-2017 08:23 AM
  1. Windows 10 Mobile build 15031 Discussion (Redstone 2; Fast Ring)
    By zocster in forum Windows 10 Mobile Insider Preview
    Last Post: 02-25-2017, 06:56 AM
  2. Destiny 2 still set for a 2017 launch
    Last Post: 02-09-2017, 06:20 PM
  3. Windows 10 Mobile build 15031 for Fast Ring released to Insiders
    Last Post: 02-09-2017, 05:20 PM
  4. Telerik open sources its UI controls for building Universal Windows Platform apps
    Last Post: 02-09-2017, 03:30 PM
  5. Minecraft aims for your sweet tooth with the Candy Pack for Windows 10 and Pocket Editions
    Last Post: 02-09-2017, 03:00 PM
