1. KGWPUSER's Avatar
    Hi guys, I wasnt sure where to post this so I apologize in advance.
    So today I was walking and pulled out my Focus Flash, the speaker wasn't working, i couldn't hear anything, after a restart it started working and i moved on. While I was sitting down playing my guitar i felt a heat in my pocket, when I took the phone out, the flash kept going on and off like a SOS message, since I was busy I decided to switch off the phone and solve the issue later. To my surprise the flash kept going on and off while it was turned off. The flash would go off for a few seconds but when i touch the power button it started back up. If I try to turn on the phone NOTHING HAPPENS, just a stupid on and off flash, and really don't know what to do, when i take out the battery it stops then as soon as i pop it back in, the flash is back up. Any help will be appreciated , thank you.
    07-08-2013 10:48 PM
  2. HeyCori's Avatar
    Never heard of this problem before. If it's a software issue then you could try a hard reset. You could also try contacting Samsung to see if the warranty is still valid. Chances are you're going to need a replacement phone.
    07-09-2013 08:47 AM
  3. KGWPUSER's Avatar
    Agreed
    07-09-2013 12:38 PM
  1. Replies: 15
    Last Post: 07-16-2014, 04:23 AM
  2. Surface Type Cover Firmware issue
    By loribinca in forum Microsoft Surface for Windows RT
    Last Post: 07-31-2013, 09:27 AM
  3. RT won't recognize HTC 8X after 8.1 update
    By HYDR0SH0K in forum Windows RT
    Last Post: 07-09-2013, 09:28 AM
  4. Flashing Lumia 928 with Lumia 920 Image
    By AR2186 in forum Windows Phone 8
    Last Post: 07-08-2013, 10:17 PM
  5. Replies: 1
    Last Post: 07-08-2013, 02:19 PM
