1. itsmejd's Avatar
    My Samsung Focus Flash have been giving me problems for at least a week now. I am unable to do ANYTHING on it. Whenever I try to send an email,play a game, watch YouTube videos, talk on the phone, etc... My phone shuts off about 2 minutes later (as if it overheated or something). I can't even turn it back on immediately, I have to wait a few minutes or plug it into a charger. I can only do things if my phone is plugged into the charger during use. I think it have something to do with the battery but im not too sure. This is only a 4 month old phone! It is very annoying! Anyone else had this problem?
    08-23-2013 09:40 AM
  2. stmav's Avatar
    It certainly would appear to be a battery problem, since everything works just fine plugged in. Have you been able to notice what your battery level is before it shuts down, and then what it is after you are able to start it back up?
    08-23-2013 10:38 AM
  3. itsmejd's Avatar
    I just tried it out. It started at about 90% charged then it shut off saying the battery was critically low. Now after I turned it back on its at about 70%.
    08-23-2013 11:03 AM
  4. stmav's Avatar
    You could try to get another battery, hopefully at a good price, and see if it does the same thing. If not then it was the battery, if it does then you'll have to look into getting it repaired if you want. But at least you'll have a spare battery.
    08-23-2013 11:49 AM
  1. Amber update problem
    By CCoutret in forum Nokia Lumia 928
    Last Post: 08-25-2013, 12:11 AM
  2. Replies: 1
    Last Post: 08-23-2013, 10:59 PM
  3. Does this Phone have Removeable Battery?
    By computerfreak123 in forum Nokia Lumia 520
    Last Post: 08-23-2013, 01:27 PM
  4. phone replacement
    By akifreestyle7 in forum New to the Forums? Introduce Yourself Here!
    Last Post: 08-23-2013, 12:12 PM
  5. Replies: 10
    Last Post: 08-23-2013, 08:56 AM
