1. breakdanzer's Avatar
    Hey guys, so I have a problem which i cant seem to fix. So i turned off my phone for 30 minutes, and when I turned it on, the lock screen looked fine. However, right after I type in my password, the homepage does not show, and the screen only displays a black screen. The black screen only shows the time in the top right corner, and none of the capacitive buttons work. I have tried to turning the phone on and off and hard reseting the phone, but nothing helps to allieve the situation. Any Help?
    11-19-2010 10:14 AM
  2. raremage's Avatar
    Pull the battery?
    11-19-2010 01:58 PM
  3. siradude's Avatar
    So you tried removing any SD card.
    Hard Reset via key combination (Vol DOWN + Camera + power)?
    If you still have problems after this you may need to return to your AT&T Store.
    11-20-2010 11:32 AM
