About 20 minutes ago, my phone's lock button stopped working...it wouldn't work to lock the phone, and a long press would not even bring up the option to turn the phone off. I then did a battery pull to try to reset the phone and get everything going again. when I tried to power it back on, the startup "SAMSUNG" screen appeared, and then a battery symbol with a little yellow hazard triangle appeared, and then the phone shut off again. I plugged it into the charger, and the phone keeps cycling those two screens. When this all occurred, the phone was still at about a 75% charge. Any ideas?!
