1. Jeffrey Fox's Avatar
    So I've been trying to view the WPCentral website on my Surface RT running the standard IE10 browser and lately its been crashing fairly consistently. After going to the site it first becomes unresponsive, not loading the entire homepage, showing the loading dots (you know the ones, at the bottom of the screen in IE10) and after a minute of frantically swiping around the screen and/or clicking on links to try to get past the homepage and into the forums the browser crashes and reloads. This is only happening with the WPCentral website on my Surface RT so I figured I'd start asking here to see if there is a known issue going on lately.
    I'm currently on my desktop PC running Windows 8 and IE10 and everything is peachy keen, trying it on my Surface RT and its crashing now. Hralp me!
    08-13-2013 05:54 PM
  2. Laura Knotek's Avatar
    I'm sorry that this site is buggy on your Surface RT.
    I've reported this bug to the tech staff.
    08-13-2013 06:45 PM
  3. stmav's Avatar
    I've been fighting the same problem for a while. It is usable if you use the desktop internet explorer.
    08-13-2013 07:35 PM
  4. DBDev's Avatar
    Strange, this doesn't happen to me...
    08-19-2013 09:52 AM
  5. James Falconer's Avatar
    ...and you're on a Surface RT w standard IE10 browser?
    If it's working for you... and NOT for Jeffrey... perhaps we can isolate what is causing the problem.
    08-20-2013 08:17 AM
  6. Jeffrey Fox's Avatar
    Happy to submit any info I can
    08-20-2013 08:21 AM
  7. DBDev's Avatar
    Yes, I'm on a surface rt with ie10. I can also submit info if you ask for something :)
    08-20-2013 08:29 AM
  8. James Falconer's Avatar
    Ok, lets start with device, OS version, browser version... also, is your browser running in 'compatibility mode' or anything like that?
    08-21-2013 08:33 AM
  9. DBDev's Avatar
    It is a 32GB Surface RT and the browser is ie10. Here's a screenshot of the about page from the browser in desktop mode. No, I don't use capability mode, but I use some TPL if that can have something to do with it.
    08-21-2013 09:35 AM
  10. James Falconer's Avatar
    Jeffrey, can you post the same info for comparison?
    08-21-2013 09:45 AM
  11. Jeffrey Fox's Avatar
    I also have the Surface RT 32gig model. IE10 in "Metro" mode, no compatibility modes or anything similar.
    https://skydrive.live.com/pagenotfounderror
    It looks like I'm running the same version of IE10 as DBDev.
    Here's an example of my problem. After I posted this thread I tried browsing around a little bit. It starts out just loading very slowly, like the site can't keep up with me scrolling down (https://skydrive.live.com/pagenotfounderror). At this point hyperlinks are dead, I can't click anywhere but I can scroll around for a little while longer. Eventually it just freezes completely, although I can still pull the tab down and close the page (https://skydrive.live.com/pagenotfounderror)
    Hope this helps.
    08-21-2013 11:36 AM
  12. James Falconer's Avatar
    Do you have any other browser processes installed and/or running in the background?
    08-22-2013 08:26 AM
  13. spyderzWPC's Avatar
    I had bing crashing my IE 10 desktop browser on my win 8 64, thing that fixed it was a fresh build. I do love the restore options on windows 8 they work great. I would suggest uninstalling the IE app and reinstalling it from the store, or check your error logs see if anything sticks out.
    08-22-2013 08:37 AM
  14. Jeffrey Fox's Avatar
    I haven't changed or added a thing to IE10, in fact I thought I wasn't able to run add-ons and the like with IE10 Metro. I should try reinstalling IE10, that probably wouldn't hurt anything.
    08-22-2013 09:06 AM
  15. DBDev's Avatar
    08-23-2013 02:15 AM
  16. Jeffrey Fox's Avatar
    I'll give that a try, thanks.
    08-23-2013 08:25 AM
  17. James Falconer's Avatar
    Let me know if that helps...
    08-26-2013 08:26 AM
  18. Jeffrey Fox's Avatar
    Well as it was suggested in that link I added the Easylist Standard (from here Internet Explorer Gallery) and the WPCentral site runs like a dream now on my Surface RT. This should be pinned in some form to alert the Surface RT folks, in my humble opinion.
    DBDev likes this.
    08-26-2013 08:35 PM
  19. James Falconer's Avatar
    Definitely... getting someone on that...
    Jeffrey Fox likes this.
    08-27-2013 08:04 AM
  20. stmav's Avatar
    I did that on my Surface yesterday as well. And for the first time in a long time, I was able to use the metro IE for normal use plus other tasks with no freeze ups or problems. Will report back in a couple of days, hopefully that it's still going strong.
    DBDev and Jeffrey Fox like this.
    08-27-2013 10:44 AM
  21. FuzzyLogician's Avatar
    Hope this helps.
    Hi there, I just wanted to report that I was having this exact same issue on my Ativ 500t (with an Atom processor). I added tracking protection like someone suggested and now things work smoothly. Thanks!
    08-27-2013 10:43 PM
  1. Replies: 10
    Last Post: 04-08-2014, 10:06 AM
  2. NO apps update notification from the store after Hard-reset
    By fantakk in forum Other Operating Systems
    Last Post: 08-31-2013, 04:33 AM
  3. Replies: 2
    Last Post: 08-14-2013, 12:59 AM
  4. A beautiful new Reddit client in the making: Readit!
    By descabar in forum General Phone Discussion
    Last Post: 08-13-2013, 06:57 AM
  5. Replies: 2
    Last Post: 08-13-2013, 01:25 AM
