1020 wifi connection problems
acousticpoem
56
Hi All
Just got 1020 today and I cant sign into home wifi. My 820 does with no problem any one else had this issue or any solutions.
nah, had zero problems connecting to wifi. both open network as well as secure (wpa2+psk)
I guess double check password? what wifi protection are you using?
I had this problem with my work WiFi internet. Keeps telling me incorrect password. Solved it by entering the router's home page and changing the security setting from wep to wpa2+psk.
Sent from my Nokia Lumia 1020 using Tapatalk
Hello there,
Go to your Wireless Setting > Manually > WPA > Cipher Type > AES
Use only AES
Do not set as TKIP
Works for me.
Cheers.
Hello!
I have updated my Nokia 1020 with Windows 10 but the WiFi doesn't work.
The WiFi button doesn't work, i mean, it is always stay on 'OFF mode'.
How can i turn this button on?
Thanks!
hosseinf
