6Snap battery drain
L3vi
75
Anyone experiencing massive battery drain with background tasks enabled? I'm using a Lumia 920.
Does this happen only with 6Snap in the background if so block it on setting then background task.
I don't know about background but when using the app I have MASSIVE battery drain. Same goes with Rudy's newest app 6tindr!
Does your battery drain only happen when u use the app or just when getting notifications a live tile updates?
It seems to occur only after I open the app for the first time after charging my phone. After I open it the battery will drain rather quickly.
grimmmmm
