Alarm volume too low. Help.
jrosariox2
Hi. I just got the Lumia 435 and I'm really liking it as an entry level device. However, I have one bit of a problem. The alarm volume is way too low. My volume is to the max and still. I know the alarm is supposed to gradually become louder once it's gone off but it just doesn't. It's always the same volume, too low. I want to alternate between this phone and my nexus 6 but without the alarms I just haven't been able to use it as I'd like. Any help? Thanks.
Same problem here with alarm volume has well on my 435. Can barely hear it has well. Even using a custom alarm sound it is still low volume. The alarm sound is no where has near loud has it should be. Not sure what to say other than report the issue to Microsoft.
I even tried with speaker facing up no help still low volume when compared to incoming calls volume.
I am going to send Microsoft Lumia support an email about the issue, not much else we can do expect that and hope maybe they will fix it.
Check the media + apps volume level if it's full to 30 then u have a problem that should be reported to Microsoft.
Silentfan the alarm uses ringer+notification volume settings not media and apps volume.
There are several threads on this subject and it is up Microsoft to fix it.
Ironmonkey810
