Battery drain after updating Chronos Calendar?
Beau Beerlage
10
Are there more people experiencing a battery drain after updating to the latest version of Chronos Calendar?
After my update yesterday, during one night I lost 30% of battery and after recharing completely I lost another 20% within 1,5 hours without any use at all and after a restart.
Not saying it is the app, but for me it could explain the issue with my battery.
Restarted my L920 twice, so there are no background tasks active.
You can use it with sync or without sync (go Chronos settings to deactivate it, if you like that way - I do that way) - you can not block that by other away (Chronos is also in advanced background settings, some you can not block) ... blocking Chronos visible background setting just stop updating of a live tile - do you really want it ?
I use Chronos as deactivated and with active live tile (unblocked visible background task) ... it consume less power that way ...
