Battery drain
Hi nucmanchh,
I moved your thread to the Nokia Lumia 920 forum.
Have you installed any new apps since you noticed the battery drain?
I've had that happen every few weeks or so. AFAIK, it's either happened after installing a new app or after blocking an app from running in the background. Each time it happened, I powered the phone of & back on and the problem went away.
bevilbody099
