Battery Saver lights left on - FIXED!!!
AndyCalling
1,483
Yes folks, the latest Device Hub update fixes this problem. You know, the one where the battery saver didn't dim the screen and switch the fixed button lights off? Well, it was always weirdly linked to Device Hub, and the latest update fixes this long time bug.
Good Times! 😁
I can say that on my 930 it is certainly working as it should. I have installed and launched the new Device Hub settings update and... Piff Puff Poof! The bug has vanished!
I can confirm also, that on my 920, the new device hub update fixes my button light behavior.
Although I can't tell for sure it fixed the display brightness.
EDIT: I think it did, just less aggressive I guess.
(woah, 7,001st post on WC!)
There's a clear difference in amoled brightness (I'm on auto brightness level) with battery saver after the fix, so I guess it'll work for LCD as well but to less effect.
OK, now that its dark, looks like it does dim the display, there's just a short delay before it dims.
Yes it's been fixed and isn't it weird it's connected to device hub? *SMH*
Also, the screen brightness is less aggressive on my 920 and like @xandros9 said, there's a short delay (BTW, congrats no your 7,001st post man)
hosseinf
