Bluetooth Issues with phone calls and audio
ThermoDust
82
So, this issue has been around since WP 8 and I am starting to think it is me, but that is why I am here is to ask all of you.
My issue is when I get or make a call on bluetooth and turn off bluetooth through the phone dialer (phone is still connected to bluetooth) and hang up the call my audio for music or anything no longer returns or plays through the bluetooth. The only way I know of fixing it is by rebooting the phone or making another call and turning on bluetooth in the phone dialer.
Anyone else have this problem?
Hi, I too have problem with Bluetooth, my phone is Lumia 535 with build 10581, Bluetooth pairing shows connected to Voice, music. when I play music, sound comes out from phone speaker not from my Bluetooth speaker.
for voice calling not able to get sound from phone as well in Bluetooth speaker. can some one help?
Your phone's Bluetooth stack firmware might be corrupted since my 1520 on 10586.107 does not have this issue (just tried it today). Either perform a hard reset or restore to 8.1 >> update to latest WM10 build >> hard reset and then start using your phone again. There is also a slight chance that the Bluetooth device you're connecting to might be the problem.
I responded earlier with my 1520's experience but now I can add that my 640 and 950 XL both don't have this issue either. They're both running .318
Thanks Pankaj, i found the issue, I use Amkette Bluetooth speaker which does not play still. I tried with Bose bluetooth speaker which works fine. So Microsoft should check this issue on different Bluetooth speakers to solve this kind of issues.
Microsoft cannot check different Bluetooth speakers from various manufacturers, as there are too many.
They can only check if their OS works fine with different Bluetooth stacks. If the devices support these stacks and protocols, they should ideally work with the OS.
grimmmmm
