Camera and Power Buttons a bit loose causing rattle?
Codeworks
34
Hello, all.
Got my Lumia 900 today and although the build quality is pretty great, the buttons on the side of the device are a bit loose and cause a little rattle. Anyone else notice this? If you tap the phone, you can hear a little rattle as well because of the buttons.
Am I being too picky? Not happening to anyone else?
Thanks.
My buttons are pretty solid. I'm not hearing any rattling. Much better than my Samsung Focus.
I also hear some rattling, like something is loose but I don't think it's the camera button. I held down the volume rocker, power button and camera button while shaking the phone gently and there was still rattling.
Seems like it's something else that is slightly loose.
I have the same rattling noise, it is definitely from the buttons and most likely the camera button since the power and rocker are pretty firm (relatively). The camera button seems to be more loose since it is a two step process button (focus, picture take). That is my best guess, but I can't decide if it is a problem that needs fixing or not.
What you guys think? I just checked and sounds is 100% from the camera button.
Don't know. Only got to touch the buttons for about 3 minutes before slipping on my gel case. No rattle here.
Sent from my Lumia 900 using Board Express
hosseinf
