camera problem--any help?
Essam H
7
something strange happen with my when i use my camera
when i take picture with my mobile it's good but after 2 seconds the resolution and quality in the picture change suddenly and become bad and not as it was taken sharp and good
i don't know why this happen
is this happen with you guys?
Try
1. Updating to Amber (improves brightness and camera picture quality)
2. Clean the camera from outside (this could be stupid :))
3. Nokia Camera application
i use nokia camera but this happen with noka camera app or with main camera app
i clean the camera from outside
i have the last update
my phone take the picture good but after 2 seconds the quality of the picture change and become bad :(
looks like some problem with JPEG compression (might be a SW issue)...so you should consider making factory settings reset (instant solution for many problems) or try some other non-nokia camera app.
Sometimes i use the Pro-Shot app which is comparable (or even better) to Nokia Camera.
If the picture quality problem persists even there - i'd try to make hard reset.
BTW. just got another idea - can be problem with SD card too. which memory do you save images to?
i m facing the same prob with my fone. Photos are now blurry and grainy. i tried using different application but didnt help.
and pics looking real bad on both laptop and mobile screens. It used to be crystal clear and now they blurry like something happened to camera hardware.
i am a bit worried about this cam problem as nokia service centers are not really efficient here if its a hardware issue.
Its the same for all nokia phones using NC app...
The pic is just getting over sampled...the pic is sharp if you zoom again
sent either from my Nokia Lumia 820 or HTC Desire HD
BigDoug69
