Can Lumia 520 works fine with 32GB memory card inside with out any problems ?? Anyone using ??
saimohan35
26
i want to buy 32GB(class 10) memory card for my nokia lumia 520. Can this mobile run without any problems with 32gb memory card. Is any one using 32gb memory card in lumia520? If you are using share your experience please.
According to Nokia you could go up to a 64 gb Micro SD Card, i put a 8 gb card in the L520 my wife uses.
So i guess 32 would do fine in yours.
My old mobile supports upto 32GB. but i kept only 8 GB memory card in it and it was not worked well and it supported only 4GB. Many mobile phones mentions like expandable upto 64 GB. but if we keep 32 gb memory card in it, its working sucks really on many devices. thats why i am asking if anyone using ???
I have a lumia 520 with 32GB sandisk microsd card class 10. It's working normally, no issues and it should. Just make sure you buy an original microsd
Sioytiiokja
