Difference between Nokia Smart Cam and Smart Shoot
Aashish Chokhani
17
Hi guys,
I just moved to GDR2 and Amber on a Lumia 920. Before the move, I was using Nokia Smartshoot as one of the camera lenses. Now with Amber, I was able to download and use Nokia Smart Cam. While using Smart Cam, I found that all that Smartshoot offers is available in Smart Cam as well (Shoot multiple select best, take smiling faces only, remove unwanted objects, etc.). Considering that, does anybody see any point in using Smartshoot anymore, if you have smartcam installed?
If not, I am thinking of removing smartshoot and gaining some of the memory space back. What do you think?
Hey, I just uninstalled Smartshoot, for me it is the same. Smart Cam at all offers better experience, and for sure will receive future updates to improve things.
minale
