Double wide tiles not displaying images on WP 7.8..HELP!!!
soumitro316
107
I just noticed this recently...most apps installed from the marketplace which support double wide tile are not displaying any image..instead it just remains blank(grey)....however it works properly for the medium sized tiles...first noticed this on flat beats,also on astronomy hub....i unpinned and repinned nextgen reader just to check and now even that live tile doesn't display the image...however all these wide tiles show the headlines or whatever on the flipside...dont know what's wrong...any help is appreciated::)
First off have you done a soft reset by holding the power button and volume down key at the same time until the phone reboots.
Ok everything except flat beats is working fine now..must be a problem with that app only...thanks anyways:)
freddieleo7
