How can I improve battery life on Surface Pro 3?
How can i improve battery life on surface pro 3
I always do lots of business away from home and i dont have a second charger to bring with, this means that i never have enough battery life to finish off my work
Re: How can i improve battery life on surface pro 3
You could try going into the battery settings and changing it to "battery saver" or whatever it's called. It'll decrease your performance though.
It might also help to turn the computer off, then turn it back on if you're not going to be using it for a while.
johnaw
