How to clear Edge cache when it's not starting anymore
Did not find how. Can you explain?
my mistake, I was remembering the old 8.1 settings
You can open edge browser, go to the history tab and clear history > when you select clear all history I believe it will give options to clear the following:
  • browsing history
  • cookies
  • cached data
  • download history
  • form data
  • passwords
  • etc
See title. It says"when not starting".
really sorry about the gaffes - have been on night and day shift -
So edge isn't opening on your lumia 950xl
What OS version is your phone on?
Have you tried a soft reset?
How did the problem start?
I am running the latest fast ring. Soft reset is not helping.
It started from nowhere. Not after the new build was installed.
Just curious, but by any chance does the following work?
Settings->system->storage->this device->temporary files->edge settings
Also can try deleting any temporary files.
Did you say this started since you installed the latest build?
Also, do you have an SD card? If you do try pulling it. My not help but worth a try
<Settings->system->storage->this device->temporary files->edge settings
Edge Settings do not start.
could be an issue with the build on fast ring. I hope you understood the risks before joining the fast ring. Many bugs that were left unnoticed in initial testing could surface up anytime, with no solutions at all (let alone be a hard reset ). If you still cannot make it work, i would strongly recommend to roll back to production , using WDRT. :)
Hard reset what it was. No more idiotic fast, shmast builds. Never. Test your **** yourself.
TheDonCoffee
